[OpenLayers-Users] vector popups misaligned after resize &
switching of google layers (with fix for Ticket #1797 applied)
RFeagin
ryan.feagin at PEACHTREEGEOGRAPHICS.COM
Mon Apr 20 14:36:42 EDT 2009
My vector points are staying aligned with the baselayer. I'm only having a
problem with the popup on the first hover after the resize and layer switch.
Vivien Deparday wrote:
> Hi,
> I encounter a similar behaviour. I've reported it at the end of the
> Ticket #1797.
> So far, I didn't have time to dig into the code to try to make a clean
> fix.
> I have made a very non-satisfactory makeshift fix which is to add :
> this.layer.map.moveTo(this.layer.map.getCenter()); at the line 360 of
> the layerswitcher control.
> But I will open a new ticket.
> Are you vector features misaligned with your baselayer too or is it only
> the popup?
> Cheers,
> Vivien
> RFeagin wrote:
>> The google resizing and switching layers(Ticket #1797) has been a problem
>> for
>> me in one of my applications. I saw that 2.8 RC1 had a fix for it, so I
>> grabbed the google.js from the 2.8 RC1 and tried using it with my 2.7
>> code.
>> I didn't see anything in the changes that looked like it would cause a
>> problem.
>> Here is what I ran into... I have a point vector layer with hover popups
>> using SelectFeature on top of google layers with sphericalMercator =
>> true.
>> When I follow the steps listed on the ticket to test the fix, the map now
>> resizes correctly (thanks) but the first time I hover over a vector, the
>> popup is in the wrong location. So it looks like the map tiles and
>> vectors
>> are realigning after the resize, but the popups aren't.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/vector-popups-misaligned-after-resize---switching-of-google-layers-%28with-fix-for-Ticket--1797-applied%29-tp2664930p2665412.html
