[OpenLayers-Users] Problems with ScaleLine Control
Gorka López Rivacoba gorka.lopez.rivacoba at gmail.com
Wed Apr 22 03:05:16 EDT 2009
Thanks for your help,
The problem is that you told me. The units in the 4326 example must be in
degrees to appears correctly in the scale bar control.
Best regards,
Gorka López
2009/4/21 Ian Turton <ijturton at gmail.com>
>  On Tue, Apr 21, 2009 at 2:27 AM, Gorka López Rivacoba <
> gorka.lopez.rivacoba at gmail.com> wrote:
>> Firstly I thought that, but it clearly appears in EPSG:4326, 0,001m and
>> 0,01ft in the scale bar
> But in fact the underlying data is in degrees - AFAIK the scale bar doesn't
> do any reprojection and just trusts you not to lie to it when you set the
> units.
> Ian
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090422/80145cd7/attachment.html
