[OpenLayers-Users] Measure Control - get distance on mouse move - part 2
Andreas Hocevar ahocevar at opengeo.org
Wed Apr 22 08:22:40 EDT 2009
the solution (if you're using trunk or 2.8) is quite simple. The snippet
below replaces the definition of measureControls in the measure example
(starting around L65)
            measureControls = {
                line: new OpenLayers.Control.Measure(
                    OpenLayers.Handler.Path, {
                        callbacks: {
                            modify: function(point, feature) {
                                measureControls.line.measurePartial(point,
                                        feature.geometry);
                        persist: true,
                        handlerOptions: {
                            layerOptions: {styleMap: styleMap}
                polygon: new OpenLayers.Control.Measure(
                    OpenLayers.Handler.Polygon, {
                        callbacks: {
measureControls.polygon.measurePartial(point,
                                        feature.geometry);
                        persist: true,
                        handlerOptions: {
As you can see, the trick is to add a modify callback to the handler,
calling the control's measurePartial method.
Regards,
Andreas.
pribram pribram wrote:
> Hi,
> Is there anything new about measuring + getting distance on mousemove?
> http://n2.nabble.com/Measure-Control---get-distance-on-mouse-move-td2503580.html
> If there is a solution, please publish it.
> Thanks,
> Pribram
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
