[OpenLayers-Users] GetFeatureInfo with loadURL
James Leveille James_Leveille at dmr.ca
Wed Apr 22 14:50:43 EDT 2009
Hi Bart,
First, thanks for the answer.
Just to let you know that using "i" as my scope works fine with :
   OpenLayers.loadURL ( url, '', i, setHTML );
but not with :
   OpenLayers.loadURL ( url, '', i, function ( response ) { setHTML ( response ); });
where I get "[object Window]" instead of the actual value if "i" printed out (as I get with the first declaration).
Aren't those two declarations equivalent ?
Again, thanks for your help.
James
-----Message d'origine-----
De : Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
Envoyé : 22 avril 2009 14:25
À : James Leveille
Cc : users at openlayers.org
Objet : Re: [OpenLayers-Users] GetFeatureInfo with loadURL
one way is to use i as your scope:
response); });
function setHTML ( response)
alert ( this );
Best regards,
Bart
James Leveille wrote:
> Hi,
> I'm trying to send a getFeatureInfo to all queryable layers.
> In the "onComplete" function, I would like to be able to "know", for
> each response, the index of the corresponding layer (the layer index
> for which the request was sent).
> But the "index" value in the "onComplete" function is always wrong
> (seems to be equal to "map.layers.length" value).
> How can I make sure the index is correctly passed ?
> Thanks a lot.
> function findLayerClick ( event )
> var url;
> var mouseLoc = map.getLonLatFromPixel ( event.xy );
> for ( var i = 0; i < map.layers.length; i++ )
> if ( map.layers[i].queryable )
> url = map.layers[i].getFullRequestString
> REQUEST: "GetFeatureInfo",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: map.getExtent().toBBOX(),
> X: event.xy.x,
> Y: event.xy.y,
> SRS: "EPSG:32187",
> INFO_FORMAT: "text/html; charset=ISO-8859-1",
> QUERY_LAYERS: map.layers[i].params.LAYERS,
> FEATURE_COUNT: 5,
> VERSION: "1.1.1",
> WIDTH: map.size.w,
> HEIGHT: map.size.h
> }, map.layers[i].url );
> OpenLayers.loadURL ( url, '', this, function ( response ) { setHTML (
> response, i ); });
> OpenLayers.Event.stop(event);
> function setHTML ( response, index )
> alert ( index );
> ... ... ... // manipulate the result
> James
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
