[OpenLayers-Users] Measure Control - get distance on mouse move
- part 2
Josh Rosenthal
maric423 at gmail.com
Wed Apr 22 19:49:17 EDT 2009
D'oh! Yes, that should have been obvious. Either use whatever is being
triggered by the modify callback, or set a custom one if the control isn't
already using one.
Much obliged,
Josh
On Wed, Apr 22, 2009 at 4:35 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Josh Rosenthal wrote:
>> Thanks a lot for the solution using callbacks. I was wondering if you
>> could suggest how that might be adapted to give the measurements on a draw
>> feature. It's much easier than what I was previously doing for measure and
>> drawFeature (passing a customized modifyFeature function in the options,
>> where the new function was the same as the original, but also had the
>> requisite getLength statements - functional, but it seems like this should
>> be far more version dependent than the callback solution).
>> When I try to use callbacks-modify on a drawFeature (as below), my modify
>> callback doesn't seem to get used (the console.log(this) never fires). I
>> assume this is because measureControls didn't already use a modify callback,
>> whereas drawFeature does, and as such drawFeature overrides any modify
>> callback I might try to pass in? Is there any way to append to the normal
>> modify callback? Am I missing something obvious?
> The best way to achieve this would be to listen for the sketchmodified
> event of the DrawFeature control. this is what actually gets triggered in
> the modify callback of the handler that is configured with DrawFeature.
> Regards,
> Andreas.
>> Thanks!
>> Josh
>> broken: uses callbacks - modify: selectDrawCircle = new
>> OpenLayers.Control.DrawFeature(selectLayerPoly,
>> OpenLayers.Handler.RegularPolygon,{
>> displayClass:"olControlSelectDrawCircle",
>> element:document.getElementById('SelectControl_Distance'),
>> unitElement:document.getElementById('SelectControl_mapUnit'),
>> callbacks:{
>> modify: function (point,feature) {
>> console.log(this);
>> this.element.value=this.radius.toFixed(2);
>> this.unitElement.innerHTML=this.map.getUnits();
>> handlerOptions:{
>> sides:40
>> functional: uses slightly customized
>> modifyGeometry function passed in as an option
>> handlerOptions:{
>> sides:40,
>> modifyGeometry: function() {
>> var angle, dx, dy, point;
>> var ring =
>> this.feature.geometry.components[0];
>> // if the number of sides ever changes,
>> create a new geometry
>> if(ring.components.length !=
>> (this.sides + 1)) {
>> this.createGeometry();
>> ring =
>> for(var i=0; i<this.sides; ++i) {
>> point = ring.components[i];
>> angle = this.angle + (i * 2 *
>> Math.PI / this.sides);
>> point.x = this.origin.x +
>> (this.radius * Math.cos(angle));
>> point.y = this.origin.y +
>> (this.radius * Math.sin(angle));
>> point.clearBounds();
>> // note, only val b/c this is an input
>> field.
>> On Wed, Apr 22, 2009 at 8:22 AM, Andreas Hocevar <ahocevar at opengeo.org<mailto:
>> ahocevar at opengeo.org>> wrote:
>> Hi,
>> the solution (if you're using trunk or 2.8) is quite simple. The
>> snippet
>> below replaces the definition of measureControls in the measure example
>> (starting around L65)
>> measureControls = {
>> line: new OpenLayers.Control.Measure(
>> OpenLayers.Handler.Path, {
>> callbacks: {
>> modify: function(point, feature) {
>> measureControls.line.measurePartial(point,
>> feature.geometry);
>> persist: true,
>> handlerOptions: {
>> layerOptions: {styleMap: styleMap}
>> polygon: new OpenLayers.Control.Measure(
>> OpenLayers.Handler.Polygon, {
>> callbacks: {
>> measureControls.polygon.measurePartial(point,
>> feature.geometry);
>> persist: true,
>> handlerOptions: {
>> As you can see, the trick is to add a modify callback to the handler,
>> calling the control's measurePartial method.
>> Regards,
>> Andreas.
>> pribram pribram wrote:
>> > Hi,
>> > Is there anything new about measuring + getting distance on
>> mousemove?
>> http://n2.nabble.com/Measure-Control---get-distance-on-mouse-move-td2503580.html
>> > If there is a solution, please publish it.
>> > Thanks,
>> > Pribram
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org <mailto:Users at openlayers.org>
>> > http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
> Andreas Hocevar
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090422/57623d64/attachment.html
