[OpenLayers-Users] Node was not found: code:8 - fixed in 2.6+ ?????
Roald de Wit roald.dewit at lisasoft.com
Mon Apr 27 18:10:50 EDT 2009
Hi Peter,
First of all, 2.8 will be released soon, so you might want to skip 2.7
altogether. Second:
getFeaturesLayer().addFeatures([.feature]);
You seem to be adding an array with a '.feature'. Note the dot.  Is that
a typo?
Why not try 2.7 or 2.8-rc1 with a development copy of your site? That's
an easy way to find out if your bug has been solved!
One more thing: FF2 has reached its end of life, so you might want to
migrate to FF3 as well.
Regards,
Roald
plen wrote:
> Hello,
> We are using OP v2.5 but will be moving to v2.7 in the next month or so.
> Currently (in v2.5) I have been getting the error 'Node was not found" code:
> "8' in Firefox (v2.0).  The error is triggered when I call:
> My feature is a "new OpenLayers.Feature.Vector(point,null,style);" where I
> define the external graphic and size, etc for the point.
> I saw two older OL trouble tickets (#1042 and #1178) which reference the
> problem, although the error may be called for different operations on the
> feature.  It looked like there was a fix in OL v2.6, but I am not sure I
> understaood that correctly.
> So, my question is to find out if the problem I am seeing in v2.5 has indeed
> been fixed and when we move to v2.7, all should be well.  Or whether it
> could still be a problem.
> Thanks - Peter
