[OpenLayers-Users] Error when using XMLHTTPRequest (throughrefreshing a wfs layer every n seconds)
Roald de Wit roald.dewit at lisasoft.com
Tue Apr 28 21:25:57 EDT 2009
Christopher Schmidt wrote:
> Kris,
> Thanks for the work on this. Two things:
>  * Since the XMLHttpRequest code is, as I understand it, primarily taken
>    from the XMLHttpRequest project (that you linked); are the changes
>    that you put in that file already included in1.0.3 of XMLHttpRequest?
>    (Unfortunately, the license for that library changed, so now I have
>    to go read the LGPL and figure out if we can just pull the latest
>    version from them.)
The license for XMLHttpRequest.js is LGPLv3 and therefore most probably
too restrictive (IANAL). The schema on the following page [1] says: you
can use BSD-new with LGPLv3 but then your project falls under the latter
license.
Maybe it's an idea to contact the author of XMLHttpRequest.js and ask
him to release under a more permissive license (as well)? He might not
realise the problems his new license is causing us (and probably more
projects).
Regards,
Roald
[1] http://www.dwheeler.com/essays/floss-license-slide.html
Roald de Wit
Software Engineer
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
