[OpenLayers-Users] FW: SelectFeatureControl invalid when set style to vector?
Kris Geusebroek kgeusebroek at xebia.com
Wed Apr 29 16:20:00 EDT 2009
Forgot to include the list. Sorry
Cheers Kris
-----Original Message-----
Sent: Wednesday, April 29, 2009 10:19 PM
To: 'shane_china'
Subject: RE: [OpenLayers-Users] SelectFeatureControl invalid when set
style to vector?
Something like this?;
	var wfsLayerStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default']);
	var wfsLayerSelectStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['select']);
	var wfsLayerTempStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['temporary']);
    var wfsPointStyle = OpenLayers.Util.extend({}, wfsLayerStyle);
	wfsPointStyle.graphicName = "${MARKERTYPE}";
	wfsPointStyle.pointRadius= 10;
	wfsPointStyle.strokeColor= "#B60000";
	wfsPointStyle.strokeWidth= 2;
	wfsPointStyle.fillColor= "#B60000";
	wfsPointStyle.fillOpacity= 1;
	var wfsLineStyle = OpenLayers.Util.extend({}, wfsLayerStyle);
    wfsLineStyle.strokeColor = "#B60000";
    wfsLineStyle.strokeWidth = 5;
    var wfsPolyStyle = OpenLayers.Util.extend({}, wfsLayerStyle);
    wfsPolyStyle.strokeColor = "#B60000";
    wfsPolyStyle.strokeWidth = 2;
    wfsPolyStyle.fillColor = "#D5D5D5";
    wfsPolyStyle.fillOpacity = 0.5;
    var wfsPointSelectStyle = OpenLayers.Util.extend({},
wfsLayerSelectStyle);
	wfsPointSelectStyle.graphicName = "${MARKERTYPE}_selected";
	wfsPointSelectStyle.pointRadius= 10;
	wfsPointSelectStyle.strokeColor= "#0000FF";
	wfsPointSelectStyle.strokeWidth= 2;
	wfsPointSelectStyle.fillColor= "#0000FF";
	wfsPointSelectStyle.fillOpacity= 0.6;
	var pointStyles = {
            "default": wfsPointStyle,
            "select": wfsPointSelectStyle,
            "temporary": wfsLayerTempStyle
	var wfsPointStyleMap = new OpenLayers.StyleMap(pointStyles,
{extendDefault: false});
	var lineStyles = {
            "default": wfsLineStyle,
            "select": wfsLayerSelectStyle,
	var wfsLineStyleMap = new OpenLayers.StyleMap(lineStyles, {});
	var polyStyles = {
            "default": wfsPolyStyle,
	var wfsPolyStyleMap = new OpenLayers.StyleMap(polyStyles,
Here 3 styleMaps are created which are used in the styleMap option of
the layer
In you're code you are overwriting the layer_style var so there is one
problem at least.
Hope this helps
Cheers Kris
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of shane_china
Sent: Wednesday, April 29, 2009 5:38 PM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] SelectFeatureControl invalid when set
style to vector?
Kris Geusebroek wrote:
> Hi Shane,
> You need to set a select style also, so extend
> Feature.Vector.style['select'] and add that to the layerstyle
> Cheers Kris
> Sent: Wednesday, April 29, 2009 2:38 PM
> style to vector?
> here is the detail code
> When I construct vecotr like this:  var vector = new
> OpenLayers.Feature.Vector(point);
> select feature control works well. When the vector was selected, color
> changed.
> But when I construct vector like this :
> var layer_style = OpenLayers.Util.extend({},
> layer_style.strokeColor = "blue";
> layer_style.fillColor = "blue";
> var vector = new OpenLayers.Feature.Vector(point, null, layer_style);
> Then the vector was selected, the color didn't change althought the
> vector
> was actually selected.
> I don't know why, is there any other style I should set?
http://n2.nabble.com/SelectFeatureControl-invalid-when-set-style-to-vect
> or--tp2739954p2740297.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
var layer_style = OpenLayers.Uitl.extend(layer_style,
I add the second line to my code. But it also doesn't work. Could you
tell
me more exactly or some simple code? Add style to layer style? But layer
style should already have some select style, I thought. Why should I add
another? Why default one doesn't work? Thank you.
or--tp2739954p2741324.html
Users mailing list
