[OpenLayers-Users] Displaying a popup on mouse over AND a
 different popup on click.
    Alexandre Dube
    adube at mapgears.com
    Mon Aug  3 08:12:04 EDT 2009
Hi Adrian,
  Take a look at this example (1).  You can use 2 SelectFeature controls
for what you need, one with hover:true and highlightOnly:true, the other
with hover false.  The first one won't actually select the feature and
you can register 3 kinds of "highlight" events (see the source) to
display your small div/popup.
Hope this helps,
Alexandre
(1) http://openlayers.org/dev/examples/highlight-feature.html
Adrian Popa wrote:
> Hello everyone,
> This is sort of a repeat message of "Re: [OpenLayers-Users]
> Labels/Tooltips on mouse over a Vector layer" - but with a slightly
> different idea.
> Problem: I want to display a small div/popup with the marker's name
> when the user hovers his mouse over the location, and I want to
> display a bigger popup when the user actually clicks on the location.
> Current status:
> * I can use {hover: true} to register
> featureselected/featureunselected when I hover over a marker instead
> on when I click on the maker.
> * I haven't found any events that could differentiate between hover
> and click
> I'm thinking I could register my select control with hover: true and
> allow featureselected to execute the same function for both when I
> click on the makrer as well as when I hover over the marker. I would
> like to know if there's any way to find out in the event inside the
> function if the user clicked or not his mouse. Depending on this, I
> would show one popup or the other.
> Something like:
> select = new OpenLayers.Control.SelectFeature(markers, {clickout:true,
> hover:true});
>         markers.events.on({ "featureselected": onMarkerSelect,
> "featureunselected": onMarkerUnselect, "visibilitychanged":
> onMarkerToggle });
>         map.addControl(select);
>         select.activate();
> function onMarkerSelect(event){
>     var feature = event.feature;
>     //find out if the user clicked or not
>     var clicked = event.*findAWayToSeeIfTheUserClicked()*;
>     if(clicked){
>        //show larger popup
>     else{
>        //show smaller popup
> Suggestions are welcome.
> Thanks,
> Adrian
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
