[OpenLayers-Users] Measure control problem
Kwong Hu Kiu kwonghu at hotmail.com
Mon Aug 3 10:47:52 EDT 2009
I think you are looking for the Vincenty distance formula.
It's included in the examples as well.
To: users at openlayers.org
Date: Mon, 3 Aug 2009 10:44:10 -0400
Subject: [OpenLayers-Users] Measure control problem
Hello,
I created a measure control based on
the measure.js example
My measure control doesn't display the
good distance. The distance is longer than expected.
I tried with these coordinates
# : lat, long
Point 1 : 46.81509864093307, -71.22436522446064
Point 2 :  45.54483148742626, -73.63037108350094
The control gives 336.824 km
It should be around 233 km
Do you have an idea on what could be
the cause of this error?
Here is my code
//the mapOptions of OL are
projection: "EPSG:900913",
displayProjection: new OpenLayers.Projection("EPSG:4326"),
//Pour afficher les coord lat long
units: "m",
var mesureControl = new OpenLayers.Control.Measure(
               OpenLayers.Handler.Path,
                   persist:
true,
      geodesic: false,
                   handlerOptions:
  layerOptions: {styleMap: styleMap}
mesureControl.events.on
    "measure": handleMeasurements,
        "measurepartial":
handleMeasurements
map.addControl(mesureControl);
function handleMeasurements(event)
        var
geometry = event.geometry;
        var
units = event.units;
        var
measure = event.measure;
        alert(
measure.toFixed(3) + " " + units, "" );
//geoExt toolbar
action = new GeoExt.Action({
        control:
mesureControl,
    map: map,
    toggleGroup: "map",
        iconCls:
'measure',
        tooltip:
'Mesure linéaire'
    toolbar.push(action);
Thanks for your help,
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090803/c9db9c3c/attachment.html
