[OpenLayers-Users] Using a more readable OpenLayers.js
Adrian Popa adrian_gh.popa at romtelecom.ro
Tue Aug 4 06:52:05 EDT 2009
Thanks, I hadn't noticed that copy. :)
Marc Jansen wrote:
> Hi Adrian,
> assuming you are using a local copy of OpenLayers, you could use
> OpenLayers-Folder/lib/OpenLayers.js
> instead of
> OpenLayers-Folder/OpenLayers.js
> which would load lots of uncompressed/non-minimized js-files.
> Regards,
> Marc
> Adrian Popa schrieb:
>> Hello,
>> I'm running into a problem where firebug says "element doesn't exist"
>> somewhere in OpenLayers code. I'm having trouble debugging this
>> issue, because my Openlayers code is pretty compact. What should I
>> include in to have OpenLayers with a more readable code? Is there an
>> intermediary file with formatting preserved which I could use
>> temporarly?
>> Thanks,
>> Adrian
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
