[OpenLayers-Users] Problem with Layer.vector
Eric Lemoine eric.lemoine at camptocamp.com
Tue Aug 4 15:29:30 EDT 2009
On Tuesday, August 4, 2009, Nicholas Efremov-Kendall
<n.e.kendall at gmail.com> wrote:
> Hi Eric,
> I'm still new to Jscript, can you clarify this a little? or point me in the right direction?
Hi. I meant install the FireBug extension in FireFox and use it to add
breakpoints in the code and watch variables. Hope this clarifies
things...
best,Nick
> On Tue, Aug 4, 2009 at 7:47 AM, Eric Lemoine <eric.lemoine at camptocamp.com> wrote:
> On Monday, August 3, 2009, Nicholas Efremov-Kendall
>> Hi all,I've been trying to implement my gml as a layer.vector, as opposed to a layer.gml. I'm loading both into the browser with the different methods, and I can from firebug that the file is getting loaded, but it's not being displayed. Thus, if I re-sent my auto-center to sites2.events, it doesn't center at all. I'm not sure what going wrong here, I thought I'd followed the examples pretty closely. Thanks (again) in advance.
>> //loads fine var      sites = new OpenLayers.Layer.GML (
>>               "Archaeological Sites", "data/siteswatr.gml",
>>               style: {pointRadius: 2.5},
>>               projection: new OpenLayers.Projection("EPSG:4326"),
>>               format: OpenLayers.Format.GML,
>>       map.addLayer(sites);
>>  // loads into browser but not displayed.
>>               var sites2 = new OpenLayers.Layer.Vector (
>>               "sites2", {projection: map.displayProjection, strategies: [new OpenLayers.Strategy.Fixed()], protocol: new OpenLayers.Protocol.HTTP({url: "data/siteswatr.gml", format: [new OpenLayers.Format.GML()]})});
>>               map.addLayer(sites2);
> Your code looks correct to me. The Fixed strategy empties the layer
> before adding features into it, which could explain why you see one
> set of features only. I'd recommend adding a break point in the fixed
> strategy's merge() method to understand what's going on.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
Eric Lemoine
