[OpenLayers-Users] Generate image
bartvde at osgis.nl bartvde at osgis.nl
Wed Aug 5 05:33:49 EDT 2009
the print service can be used without MapFish client, it is fed by JSON.
The MapFish PrintProtocol is the communication layer you can use. But it
is not required.
Best regards,
Bart
> But in that case i would have to change all my application to MapFish,
> wouldn't I?
> Thanks,
> Albert Batiste.
> El mié, 05-08-2009 a las 11:16 +0200, bartvde at osgis.nl escribió:
>> Try out the MapFish print service.
>> Best regards,
>> Bart
>> > Hi! I'm trying to generate an image of a map that has a WMS layer and
>> an
>> > OpenLayers.Layer.Vector of features that are markers. I followed the
>> > "Tile stitching" method in http://trac.openlayers.org/wiki/Printing.
>> The
>> > problem is that i can generate an image of the WMS layer, but the
>> > markers are not showing as they belong to a layer that is not tiled.
>> > Anyone has any idea of how to do this?
>> > Thanks!
>> > Albert Batiste.
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
