[OpenLayers-Users] OL, WFST-T, Geoserver | Problem on update
Jerome Freyre jerome.freyre at hispeed.ch
Thu Aug 6 09:50:02 EDT 2009
Hi Kris,
It seems you are right... I tried to update only one column at time.
It works for all column except those one:
		<wfs:Property>
			<wfs:Name>the_geom</wfs:Name>
			<wfs:Value>
				<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#EPSG:21781">
					<gml:pos>538698.2299984342 182479.15984712465</gml:pos>
				</gml:Point>
			</wfs:Value>
		</wfs:Property>
EXCEPTION:
org.xml.sax.SAXParseException: The prefix &quot;gml&quot; for element
&quot;gml:Point&quot; is not bound.
The prefix &quot;gml&quot; for element &quot;gml:Point&quot; is not bound.
		<wfs:Property>
			<wfs:Name>rue</wfs:Name>
			<wfs:Value>COIN DE TERRE, Rue du</wfs:Value>
		</wfs:Property>
EXCEPTION:
org.geoserver.wfs.WFSException: update error
	at
org.geoserver.wfs.response.v1_1_0.TransactionResponse.write(TransactionResponse.java:49)
	at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
	at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
	at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
	at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
	at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
Do you have an idea for those exception?
Kris Geusebroek wrote:
> Hi Jerome,
> Could it be the data? The invalidParameterValue exception in combination
> with the value 48/6 in the id_comb column looks a bit tricky to me.
> Perhaps the / needs to be encoded or escaped or so?
> Cheers Kris
View this message in context: http://n2.nabble.com/OL%2C-WFST-T%2C-Geoserver-%7C-Problem-on-update-tp3397344p3398368.html
