[OpenLayers-Users] What is the relationship between zoom level and longitude/latitude
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Aug 7 07:24:51 EDT 2009
There is a function just for that:
http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.zoomToExtent
If you need the value, you can call this:
http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getZoomForExtent
You can examine the code if you are interested in the inner workings of
calculating a zoom level from a rectangle.
Regards, Kenneth Skovhede, GEOGRAF A/S
Adrian Popa skrev:
> Hello everybody.
> I'm trying to zoom to view an area for which I have the minimum and
> maximum longitude/latitude. Basically I would like to zoom in to see a
> rectangle with known coordinates. I already calculated the center of
> this rectangle - so that's not a problem - the map centers beautifully
> to that.
> The problem is: I have to find out which minimum zoom setting would
> allow my area to be fully visible - so I need to choose a zoom setting.
> There must be a relationship between the difference in longitude (or
> latitude) to a zoom level.
> I wonder if anyone knows this relationship - or should I determine it
> empirically.
> Thank you.
> By the way, my map is using spherical mercator projection, but my
> coordinates are in longitude/latitude (although there is no problem in
> converting them...).
