[OpenLayers-Users] Bug in Google with overaly example
Rodolfo Moreno rodolfoamoreno at gmail.com
Tue Aug 11 15:33:29 EDT 2009
Thanks Eric for your answer. I am overlapping a mapguide layer. I did what
you suggested but it's not working.
var dynamicOverlayOptions = {
              buffer: 1,
              singleTile: true,
	isBaseLayer : false,
	visibility : true,
	transparent:true // This is the code added
Is this property (transparent:true) new?
I ask about it because my sample works fine 3 months ago.
Thanks in advance
Eric Lemoine-2-2 wrote:
> On Sat, Aug 8, 2009 at 12:35 AM, Rodolfo Moreno<rodolfoamoreno at gmail.com>
> wrote:
>> Hi all,
>> The google with overlay example from
>> "http://openlayers.org/dev/examples/"
>> is working incorrectly. The bug is not only because the worldmap is not
>> loaded correctly but also because this is covering whole the map and thus
>> the google layer is not showed, just the worldmap is showed. if you turn
>> off
>> the worldmap layer then it's possible to view the google layer. I
>> realized
>> about it because I have a similar example overlaping google maps with
>> mapguide layers and 3 months ago this sample worked appropriately (in
>> that
>> moment the last release was 2.6 version) and now I got the same bug, it
>> means that mapguide layers covers whole map that don't enable to view the
>> google layers.
> The layer you put on top of the google layer must be transparent. If
> your layer if a WMS layer (OpenLayers.Layer.WMS) use transparent:true
> in the layer params.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Bug-in-Google-with-overaly-example-tp3407076p3426344.html
