[OpenLayers-Users] Disappearing layers
    eoinyp
    eoinyp at yahoo.com
    Thu Aug 13 09:52:19 EDT 2009
Perfect! :)
Thank you Jerome.
--- On Thu, 13/8/09, Jerome Freyre (via Nabble) <ml-user+114850-1335474129 at n2.nabble.com> wrote:
From: Jerome Freyre (via Nabble) <ml-user+114850-1335474129 at n2.nabble.com>
Subject: Re: [OpenLayers-Users] Disappearing layers
To: "eoinyp" <eoinyp at yahoo.com>
Date: Thursday, 13 August, 2009, 12:40 PM
Hi Eoinyp,
I watched your code. I think you made a mistake with the zoom level on the function map.setCenter().
Try to modify the line like that:
map.setCenter(new OpenLayers.LonLat(17, 43), 12);
It should work ;)
Here is the copy of your code that I used and modify:
                map = new OpenLayers.Map("map");
                map.addControl(new OpenLayers.Control.LayerSwitcher());
                //create layer
                var  velayer = new OpenLayers.Layer.VirtualEarth(
                        "Roads Layer",
                                'type': VEMapStyle.Road
                var velayer2 = new OpenLayers.Layer.VirtualEarth(
                        "Aerial Layer",
                                'type': VEMapStyle.Aerial
                map.addLayers([velayer, velayer2]);
                map.addControl(new OpenLayers.Control.PanZoomBar());
                map.addControl(new OpenLayers.Control.ScaleLine());
                map.addControl(new OpenLayers.Control.MousePosition());
Sincerly,
Jérome
eoinyp wrote:
Im a newbie, having problem with my map layers. Which ever layer I add first is visible when the map loads, but when I try to switch layers they both disappear. I seem to be missing something fundamental, though I cant figure out what!!
I am creating the layers and map as follows:
 init(){
create layer 1
create layer 2
add([layer1,layer2])
add[map controls]
The map can be seen at: http://www.eoinmaca.com/maps/OpenLayers/mymap.htm
Any help greatly appreciated,
Thanks,
Eoinyp
View message @ http://n2.nabble.com/Disappearing-layers-tp3436866p3437329.html
To unsubscribe from Disappearing layers, click here.
View this message in context: http://n2.nabble.com/Disappearing-layers-tp3436866p3438091.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090813/2a132934/attachment.html
