[OpenLayers-Users] Displaying a popup on mouse over AND a different popup on click. [SOLVED]
Alexandre Dube adube at mapgears.com
Thu Aug 13 13:51:54 EDT 2009
Esteban olm wrote:
> Hi,
> I'm sorry, but I have a problem.
> When I implement this, I can "pan" the map, and when I go over a
> marker, A popup appears, and when I go out of the marker, the popup
> disappear.
> That's ok, but after the popup has appear an disappear, now I can not
> "pan" the map.
> Maybe the popup has deactivated something.
Use firebug to check if your pan control is active or not, or you could
also use the firebug "Inspect" button to see if there's an extra div
over your map.
Best of luck,
Alexandre
> Can anyone help me?
> Thanks
>   Esteban Olm
Alexandre Dubé
Mapgears
www.mapgears.com
