[OpenLayers-Users] Starting function if layerstatus is changed
Kai Behncke Kai-Behncke at gmx.de
Fri Aug 14 09:02:14 EDT 2009
Hi Adrian, Hi Alexandre,
thank you for your hints, nevertheless I didn`t get it.
With "my_layer.visibility" I will get easily the status (true/false),
but the problem I have is that I don`t know how to get the function setVisibility() (that is called after activatin/deactivating a layer in Control.LayerSwitcher).
I mean:
I turn the layer on/off and the function obviously is called.
But how can I do a request on that?
Something like:
if (setVisibility()) {
alert ("change");
alert (my_layer.visibility);
of
If this.map.events.triggerEvent("visibilitychanged")) {
Well, I will try on.....
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Fri, 14 Aug 2009 15:37:30 +0300
> Von: Adrian Popa <adrian_gh.popa at romtelecom.ro>
> An: Kai Behncke <Kai-Behncke at gmx.de>
> CC: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Starting function if layerstatus is changed
> Hello Kai,
> Not sure if this is what you're looking for, but I registered my
> function to run when the layer changes visibility (is toggled on/off):
> markers.events.on({ "featureselected": onMarkerSelect,
> "featureunselected": onMarkerUnselect, *"visibilitychanged":
> onMarkerToggle* });
> markers is a Vector layer, but the event should be available for every
> layer. You can check in your function to see if the layer has been
> toggled off or on by looking at markers.visibility:
> *function onMarkerToggle(event) {
>         //do something if visibility becomes true
>         if(markers.visibility == true){
>           alert("This layer just turned visible!");
> Regards,
> Adrian
> Kai Behncke wrote:
> > Dear users,
> > I would like to start a function if the layer is on/off.
> > I tried e.g.
> > if (this.map.events.triggerEvent("changelayer")){
> > alert ("here we go");
> > and
> > if (my_layer.display()){
> > ...but so far without success.
> > Can anybody help please?
> > Thank you very much, Kai
> Adrian Popa
> NOC Division
> Network Engineer
> Divizia Centrul National de Operare Retea
> Departament Transport IP & Metro
> Compartiment IP Core & Backbone
> Phone: +40 21 400 3099
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
