[OpenLayers-Users] Vector file as base map
Jeremy Husmann Jeremy.Husmann at critchlow.co.nz
Sun Aug 16 03:44:24 EDT 2009
Great, found that out about 20 minutes after sending the email.
Thank you for your help Marc and Eric!
Cheers guys,
Jeremy
 JEREMY HUSMANN
SOFTWARE ENGINEER
CRITCHLOW LTD
LEVEL 2, 22 THE TERRACE, PO BOX 4103
WELLINGTON, NEW ZEALAND
FREE PHONE: 0800 627 746
DIRECT DIAL: +64 4 910 6208
TEL: +64 4 472 8244
FAX: +64 4 472 6695
KNOW WHERE | WWW.CRITCHLOW.CO.NZ
WARNING - THIS EMAIL TRANSMISSION IS CONFIDENTIAL
This email transmission (including any accompanying attachments)
contains confidential information, which may be subject to legal
privilege intended for the named addressee. If any other reader is not
the intended recipient, you are hereby notified that any use,
dissemination, distribution or reproduction of this email is prohibited.
If you have received this email in error please contact us immediately.
-----Original Message-----
Sent: Saturday, August 15, 2009 8:36 PM
To: Jeremy Husmann
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Vector file as base map
Hi Jeremy,
simply pass in
isBaseLayer: true
as a part of the options-Object when constructing your vector layer.
Regards,
Marc
Jeremy Husmann schrieb:
> Hello everyone,
> Just a quick question.
> Im wanting to stand up a basic webpage using standard OpenLayers, but
> I want to be displaying a default KML or GML. But without any base map
> underneath - i.e. the vector file to be the base map. Is this
> possible? And if so how would you recommend starting this?
> Cheers,
> Jeremy
> *JEREMY HUSMANN***
> SOFTWARE ENGINEER
> *CRITCHLOW LTD***
> TEL: +64 4 472 8244
> FAX: +64 4 472 6695
> _ _
> *KNOW WHERE** | WWW.CRITCHLOW.CO.NZ
<../../../../Ian/Application%20Data/Microsoft/Signatures/WWW.CRITCHLOW.C
O.NZ>*
> prohibited. If you have received this email in error please contact us
> immediately.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
