[OpenLayers-Users] can't get a right german map as an overlay working
jopix jdev at lucky-day.de
Sun Aug 16 11:41:44 EDT 2009
i am working on a project for information for german elections - try to get a
map with several category layers working.
Base should be an image: a map of germany
(http://de.wikipedia.org/w/index.php?title=Datei:Bundestag_Wahlkreise_2009.svg&filetimestamp=20081010175633)
All logic seems to be ok, can add layers with categories on top of the image
- > but i can't get the right view (maybe projection?) of the map.
It is allways a compressed view.
There are only the image, xml-files - no mapserver, no backend.
What's wrong with my code?
Any Idea to let it look like the original image?
Thank you.
*******MAP********
// Map options:
          // start with no controls, restrict view to just Germany, allow 4
different zoom options
          var map_options = {
                          	controls: [],
                          	scales: [5000000, 4000000, 3000000, 2000000,
1300000],
				maxResolution: 30000/1024,
				projection:"EPSG:4326",
				maxExtend: new OpenLayers.Bounds(5.25075, 47.2441, 15.425,	55.0317)
       	// Generate the map
          map = new OpenLayers.Map('map', map_options);
	  var graphic = new OpenLayers.Layer.Image(
	                                'Deutschland',
	                                'hts/g_election_districts_2005_02_v1.png',
47.2441, 15.425,55.0317),
	                                // Not sure exactly what Size controls
	                                new OpenLayers.Size(80, 110),
View this message in context: http://n2.nabble.com/can%27t-get-a-right-german-map-as-an-overlay-working-tp3453890p3453890.html
