[OpenLayers-Users] CGI and Tomcat
Juan Arévalo arevaco90 at yahoo.es
Sun Aug 16 17:13:06 EDT 2009
Hi!
I have finally managed to display my WFS example in the map! It is not so
obvious to set up the proxy host in Tomcat! I would like to share with you
all the steps  I followed, in case that someone need it:
1.- I modified the file: "web.xml" C:\Archivos de programa\Apache Software
Foundation\Tomcat 5.5\conf\web.xml. I uncomented the following lines of
code:
    <servlet>
         <servlet-name>cgi</servlet-name>
<servlet-class>org.apache.catalina.servlets.CGIServlet</servlet-class>
        <init-param>
              <param-name>debug</param-name>
              <param-value>0</param-value>
        </init-param>
        <init-param>
              <param-name>cgiPathPrefix</param-name>
              <param-value>WEB-INF/cgi</param-value>
        </init-param>
        <load-on-startup>5</load-on-startup>
    </servlet>
    <servlet-mapping>
          <url-pattern>/cgi-bin/*</url-pattern>
    </servlet-mapping>
You have also to add this piece of code:
      <param-name>executable</param-name>
        <param-value>c:\python25\python.exe</param-value>
       </init-param>
<init-param>
<param-name>passShellEnvironment</param-name>
<param-value>true</param-value>
</init-param>
2.- I renamed the file servlets-cgi.renametojar to servlets-cgi.jar under
the folder: C:\Archivos de programa\Apache Software Foundation\Tomcat
5.5\server\lib
3.- I downloaded the "proxy.cgi" file from Openlayers:
http://trac.openlayers.org/browser/trunk/openlayers/examples/proxy.cgi and
copy the file in a folder called "cgi-bin" that I created under my
directory: "C:\Archivos de programa\Apache Software Foundation\Tomcat
5.5\webapps\client\WEB-INF\cgi\proxy.cgi"
4.- In the proxy.cgi file I included my machine in the allowed hosts:
allowedHosts = ['demo.mapfish.org', 'localhost:5000', 'localhost',
'127.0.0.1']
5.- I included this piece of code in my map:
OpenLayers.ProxyHost = "/client/cgi-bin/proxy.cgi?url=";
6.- I also included in our client folder the context.xml file:
5.5\webapps\client\META-INF\context.xml
Make sure that the privileged is set to: "true":
<Context privileged="true" antiResourceLocking="false"
antiJARLocking="false" />
7.- Restart Tomcat.
Juan
Juan Arévalo wrote:
> Hi list,
> I am still having some difficulties to set up the proxy host in Tomcat.
> Here are the steps I followed:
> code:
>     <servlet>
>         <init-param>
>         </init-param>
>         <init-param>
>         </init-param>
>     </servlet>
>     <servlet-mapping>
>     </servlet-mapping>
> 5.5\server\lib
> directory: "Tomcat 5.5\webapps\MapFish-1.1\client\cgi-bin\proxy.cgi"
> '127.0.0.1'] and I also added this line:
> #!c:/python25/python.exe -u (I already had installed python in my PC)
> OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> 6.- I restarted my Tomcat.
> I do not see the openlayers.org website when I typed:
> http://127.0.0.1:8080/MapFish-1.1/client/cgi-bin/proxy.cgi, I got the 404
> error.
> Does anyone knows what I missing?
> Thanks again Eric and Michogar!
> Juan
> Eric Lemoine-2-2 wrote:
>> On Thursday, August 6, 2009, Juan Arévalo <arevaco90 at yahoo.es> wrote:
>>> Hi all,
>>> I am making some progress setting up a WFS-T, it seems that my code
>>> works
>>> since I don´t get any error, but the layer doesn't display in the map.
>>> I
>>> have read that this problem can be solved by setting the Proxy Host,
>>> however
>>> I was not able to set it up. I am using: Tomcat 5.5, Geoserver 1.5.3 and
>>> OpenLayers 2.8 and MapFish 1.1.(I couldn´t only find the steps for
>>> Apache
>>> but not for Tomcat)
>>> Does anyone have any ideas on how to solve it?
>> Hi. If your Tomcat instance serves both the HTML page and the WFS then
>> you don't need a proxy.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/CGI-and-Tomcat-tp3400100p3454948.html
