[OpenLayers-Users] Using Openlayers with Tile and Export Image doesnt "overlap"
RajeevSharma rajeev.kumar.sharma at gmail.com
Mon Aug 17 05:34:25 EDT 2009
Many thanks for the response Christopher.
I am sorry, since I am unable to share the map service as it is outside the
public network.
I am able to get the max extents easily, however, I am unable to find out
which resolution value to take.
As an example , say I have 3 layers which are cached. The images are 512 by
512 pixels.
max Extents are (-180, -90, 180, 90).
Layer 1 - Resolution 1058.33
Layer 2 - Resolution 529.16
Layer 3 - Resolution 132.29
I had read in the news group the max resolution should be something like
(Max (Xmax - Xmin), (Ymax - Ymin))/512, is this correct?
- Thanks in Advance,
Rajeev
Christopher Schmidt-2 wrote:
> On Thu, Aug 13, 2009 at 05:05:18AM -0500, RajeevSharma wrote:
>> Hello,
>> I am using Open Layers for the first time, and would like to display maps
>> from multiple services.
>> 1. A Tiled map service which forms the background.
>> 2. One or more Dynamic map services which will be used to overlay on top
>> of
>> the first service.
>> I am using the XYZ and ArcGIS93Rest respectively to do the same. The maps
>> do
>> display but their images arent synchronised. Meaning, the tiled layer
>> image
>> comes up on the top left part of the screen, and the export map from the
>> Rest service comes up in the centre and larger than the tiled map.
>> I tried tweaking around with the resolution param which didnt help much.
>> The
>> maps moved a bit closer until 4000 then they started moving apart.
>> Setting
>> this to "auto" didnt help either. The SRS is the same for both services.
>> As
>> are the map initial and final extents.
>> Can any one please let me know if I am doing something wrong out here?
> the XYZ layer requires you to have correct maxExtent and maxResolution
> properties matchingthe grid set up in the tile cache creation
> configuration.
> Without this information, they will not line up. Your Tile Cache metadata
> may provide this information, or you may need to consult some othr
> resource
> to find it. Sharing a link to the tiles you are trying to use, as well as
> the code you are using to try to use thm, may be helpful.
> Best Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Using-Openlayers-with-Tile-and-Export-Image-doesnt-%22overlap%22-tp3436851p3457473.html
