[OpenLayers-Users] KML reprojection?
Jeremy Husmann Jeremy.Husmann at critchlow.co.nz
Mon Aug 17 20:18:23 EDT 2009
Hello everyone,
I am in the process of adding a KML as a baselayer (I was quickly helped
by Eric and Christopher by finding the constructor attribute need for
this.).
Now I seem to have stuck another in relation to projections.
I have noticed that if I add the KML as the only base layer it comes out
a bit squashed, when if I don't change any projection settings and just
add a WMS layer as another base layer it seems to correct the KML. -
Unsure if anything is going on behind the scenes (with my KML being
reprojected?) or if im just missing something extremely obvious. - Any
help would be appreciated.
        function mapInit()
                        var nzBounds = new OpenLayers.Bounds(165, -47,
180, -34.5).transform((new OpenLayers.Projection("EPSG:4326")), (new
OpenLayers.Projection("EPSG:900913")));
                        var options =
                                    projection: new
OpenLayers.Projection("EPSG:900913"),
                                    displayProjection: new
OpenLayers.Projection("EPSG:4326"),
                                    units: "m",
                                    maxResolution: 16543.0339,
                                    maxExtent: nzBounds,
                                    numZoomLevels: 24,
                                    minZoomLevel: 6,
                                    maxZoomLevel:18,
                                    controls: [
                        new OpenLayers.Control.Navigation(),
                        new
OpenLayers.Control.LayerSwitcher({'ascending':false}),
                                    new
OpenLayers.Control.PanZoomBar({zoomWorldIcon:true})
                map = new OpenLayers.Map('map', options);
                        map.addControl(new
OpenLayers.Control.LayerSwitcher());
                                    var mapnik = new
OpenLayers.Layer.TMS(
                "OpenStreetMap (Mapnik)",
                "http://tile.openstreetmap.org/",
                    type: 'png',
                    displayOutsideMaxExtent: true,
                    attribution: '<a
href="http://www.openstreetmap.org/">OpenStreetMap</a>'
                mapnik.setVisibility(false);
                        var time = new Date();
                        var secs = time.getSeconds();
                        postCodeKml = new
OpenLayers.Layer.GML("CoverageTEST", "kml/coverage_1.kml?" + secs,
                    format: OpenLayers.Format.KML,
projection:map.displayProjection,
                            isBaseLayer:true,
                            formatOptions: {
                        extractStyles: true,
                        extractAttributes: true
               map.addLayers([mapnik]);
                        postCodeKml.setVisibility(true);
                        map.addLayer(postCodeKml);
                        postCodeKml.setOpacity(0.25);
                        map.zoomToExtent(nzBounds);
                map.addControl(new OpenLayers.Control.MousePosition());
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090818/053dba70/attachment.html
