[OpenLayers-Users] Problem with a WFS request
Arthur Delorme delorme.ipgp at gmail.com
Fri Aug 21 06:54:55 EDT 2009
Thank you for your answer.
If I understand, the BBOX strategy option will do the stuff with the
limits to take into account for not reading the whole data. I have some
other questions :
- I am not sure which URL to put for "featureNS"?
- I also had a problem of GML format : I used the option
OUTPUTFORMAT=GML2 in the URL request, because I could not make
OpenLayers read GML3 (it's probably possible but I don't know how). How
can I put this option in the code of the layer ? If it's not possible,
how can I read the GML3 Mapserver is generating with OpenLayers ?
Best regards,
Arthur
bartvde at osgis.nl a écrit :
> Hi,
> please check examples\wfs-protocol.html for the right way to do this as of
> OpenLayers 2.8.
> Best regards,
> Bart
>> Hello,
>> I am trying to display part of the data of a big shapefile with a WFS
>> request and BBOX to filter the data and display only the vectors
>> contained in the map view.
>> I just finished configuring the WFS server (Mapserver) : URL request is
>> working and I could read the XML that I saved in a file with OpenLayers
>> (for testing). Now I try to make the WFS request with OpenLayers and I
>> don't understand what is the problem. I tried two solutions based on
>> what I found on the net. Here is my OpenLayers code :
>> var map, wms, test_WFS;
>> function init()
>>     map = new OpenLayers.Map('map', {
>>         controls: [new OpenLayers.Control.Navigation(),
>>             new OpenLayers.Control.PanZoom(),
>>             new OpenLayers.Control.LayerSwitcher()
>>     wms = new OpenLayers.Layer.WMS("OpenLayers WMS",
>>         "http://labs.metacarta.com/wms/vmap0",
>>         {layers:'basic'
>> //  test_WFS = new OpenLayers.Layer.WFS("test WFS",
>> "http://IP-address/cgi-bin/mapserv_5.4.1?map=/var/www/html/WFS_server/test.map&",
>> //      {service:'WFS', version:'1.1.0', request:'GetFeature',
>> bbox:'70,35,75,37', typeName:'aster_gdem', outputFormat:'GML2'},
>>     test_WFS = new OpenLayers.Layer.GML("test WFS", [
>>         "http://IP-address/cgi-bin/mapserv_5.4.1",
>>         "?map=/var/www/html/WFS_server/test.map",
>>         "&SERVICE=WFS",
>>         "&VERSION=1.1.0",
>>         "&REQUEST=GetFeature",
>>         "&BBOX=70,35,75,37",
>>         "&TYPENAME=aster_gdem",
>>         "&OUTPUTFORMAT=GML2"].join(",")
>>     map.addLayers([wms, test_WFS]);
>>     map.zoomToMaxExtent();
>> The test_WFS layer is not displaying and I don't know how to fix it.
>> Thank you for your help !
>> Arthur Delorme
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
