[OpenLayers-Users] Adding new features: WFS-T PostGIS
Alexandre Dube adube at mapgears.com
Fri Aug 21 07:54:53 EDT 2009
Hi Juan,
  Here's an old OpenLayers demo using WFS-T with TinyOWS (using a
PostGIS DB) (1).  You have the same example using the MapFish and ExtJS
API (2).  Click on the "ModifyFeature" icon then on a feature.
  See the code for more details.
Regards,
Alexandre
(1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
(2) http://dev4.mapgears.com/bdga-mapfish/bdgaWFS-T.html
Juan Arévalo wrote:
> Hi all,
> In case that someone is stuck with the same problem that I had I attached
> the code that works for me.
> By the way, Can anyone point me to some examples using a web form to enter
> and modify attributes store in a PostGIS DB via WFS-T?
> Thanks for your help!
> //WFS Layer
> wfs3 = new OpenLayers.Layer.WFS(
>                 "Same Water Points",
>                 "http://localhost:8080/geoserver/wfs",
>                 {typename: 'cite:water_points'},
>                     typename: "water_points",
>                     featureNS: "http://www.opengeospatial.net/cite",
>                     extractAttributes: false,
>                     commitReport: function(str) {
>                         OpenLayers.Console.log(str);
> 		var saveStrategy = new OpenLayers.Strategy.Save({
>        callback: function() {
>            alert('feature saved');
> map.addLayers([wfs3]);
> //BUTTONS:
> var panel = new OpenLayers.Control.Panel({
>                 displayClass: "olControlEditingToolbar"
>             var draw = new OpenLayers.Control.DrawFeature(
>                 wfs3, OpenLayers.Handler.Point,
>                     handlerOptions: {freehand: false, multi: true},
>                     displayClass: "olControlDrawFeaturePoint"
> 			var modify = new OpenLayers.Control.ModifyFeature(wfs3, {
>                 title: "Modify Feature",
> 				displayClass: "olControlModifyFeature"
> 			 var del = new DeleteFeature(wfs3, {title: "Delete Feature"});
> 			 var save = new OpenLayers.Control.Button({
>                 trigger: OpenLayers.Function.bind(wfs3.commit, wfs3),
>                 displayClass: "olControlEditingToolbar",
> 				title: "Guardar"
>             panel.addControls([
>                 new OpenLayers.Control.Navigation(),
>                 save, del, modify, draw
>             map.addControl(panel);
> Juan Arévalo wrote:
>> Hi All,
>> I am trying to set up a WFS-T using Geoserver 1.7.6 and PostGres 8.4. I
>> have tried with the following code in order to insert new features:
>> //WFS LAYER:
>> wfs = new OpenLayers.Layer.WFS(
>> 				"Cities",
>> 				{typename: 'cite:ciudades'},
>> 				{featureNS: 'http://www.opengeospatial.net/cite',
>> 				srsName:            'EPSG:4326',
>> 				version: "1.0.0",
>> 				//schema:
>> "http://localhost:8080/geoserver/wfs?request=GetFeature&typeName=ciudades&outputformat=text/xml;%20subtype=gml/3.1.1",
>> 				//schema:
>> "http://localhost:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=cite:ciudades",
>> 				schema:
>> "http://127.0.0.1:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=cite:ciudades",
>> 				extractAttributes: true});
>> 				wfs.style = OpenLayers.Util.applyDefaults({strokeColor: "#0000ff"},
>>                OpenLayers.Feature.Vector.style["default"]);
>> //SAVE BUTTON:
>>                 trigger: OpenLayers.Function.bind(wfs.commit, wfs),
>>                 displayClass: "olControlSaveFeatures"
>> When I click the save button I got this error:
>> WFS Transaction: FAILED <?xml version="1.0" ?>
>> <ServiceExceptionReport
>>    version="1.2.0"
>>    xmlns="http://www.opengis.net/ogc"
>>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>    xsi:schemaLocation="http://www.opengis.net/ogc
>> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
>>    <ServiceException>
>>       Feature type &apos;featureMember&apos; is not available:
>> </ServiceException></ServiceExceptionReport>
>> The geoserver log is as follow:
>> 2009-08-19 20:57:35,500 ERROR [geoserver.ows] -
>> org.geoserver.wfs.WFSTransactionException: Feature type 'featureMember' is
>> not available:
>> 	at org.geoserver.wfs.Transaction.execute(Transaction.java:222)
>> 	at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
>> 	at
>> org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
>> Does anyone have any idea on how to solve this issue?
>> It would be great if you can provide me with some working examples..
>> Thanks:)-
>> Juan
Alexandre Dubé
Mapgears
www.mapgears.com
