[OpenLayers-Users] Problem with a WFS request
Arthur Delorme delorme.ipgp at gmail.com
Fri Aug 21 10:30:49 EDT 2009
I have no attributes because I use "gml_exclude_items" "all" (for now I
only need the vectors to display so I thought it was good to minimize
the request because it's a huge file). But I tried without, with
"gml_include_items" "all" and with the inclusion of the ID attribute
only, I can see all these results in the XML flow but still not my
vectors in OpenLayers.
I hope I am looking at the right place in Firebug : I am looking at the
Network tab and I see the WFS request. I am working with two computers :
one is the WFS server and the other is my working computer, with
OpenLayers and the webpage (I am working on a local server: MAMP on this
computer). The two computers are in a local network so I don't think
there is any problem with this (no proxy).
So I have two requests in Firebug :
- one is a request to the local server (MAMP) called
"http://localhost:8888/test_WFS/test_WFS.php"
- the other is a request to the second computer :
"http://IP/cgi-bin/mapserv_5.4.1?map=/var/www/html/WFS_server/test.map"
Is this normal that there is no options after the address of the mapfile
? When I look at the URL request I did for testing I see the SERVICE,
TYPENAME, BBOX, etc. Also there is no data download.
Best regards,
Arthur
bartvde at osgis.nl a écrit :
> Your GML looks okay to me. You don't have any attributes (next to the
> geometry), but that should be no problem.
> Can you see the request go off with Firebug at all when adding the vector
> layer to your map? Are you using a proxy in between or is the traffic
> local?
> Best regards,
> Bart
