[OpenLayers-Users] Problem with a WFS request
Arthur Delorme delorme.ipgp at gmail.com
Mon Aug 24 04:08:51 EDT 2009
Hi Bart,
When the webpage is loading or when I play with the layer switcher, I
don't have anything displaying in the console tab (XMLhttp is on). So I
made the test with all the files on the second computer (the one with
mapserver) and it works !
Do you have any idea for this network problem ? I can work on the second
computer also so it's not really a problem but I would like to
understand what's happening. Maybe it's just because I am working with a
local server, not a true one ?
Thank you very much for your help and patience !
Best regards,
Arthur
bartvde at osgis.nl a écrit :
> Hi Arthur,
> check out the console tab of Firebug, and make sure XMLHttp requests are
> on (check out options on the right in Firebug).
> It's because OpenLayers uses POST by default for WFS, so that's why you
> don't see any parameters. You will see the POST body though in Firebug.
> Best regards,
> Bart
>> I have no attributes because I use "gml_exclude_items" "all" (for now I
>> only need the vectors to display so I thought it was good to minimize
>> the request because it's a huge file). But I tried without, with
>> "gml_include_items" "all" and with the inclusion of the ID attribute
>> only, I can see all these results in the XML flow but still not my
>> vectors in OpenLayers.
>> I hope I am looking at the right place in Firebug : I am looking at the
>> Network tab and I see the WFS request. I am working with two computers :
>> one is the WFS server and the other is my working computer, with
>> OpenLayers and the webpage (I am working on a local server: MAMP on this
>> computer). The two computers are in a local network so I don't think
>> there is any problem with this (no proxy).
>> So I have two requests in Firebug :
>> - one is a request to the local server (MAMP) called
>> "http://localhost:8888/test_WFS/test_WFS.php"
>> - the other is a request to the second computer :
>> "http://IP/cgi-bin/mapserv_5.4.1?map=/var/www/html/WFS_server/test.map"
>> Is this normal that there is no options after the address of the mapfile
>> ? When I look at the URL request I did for testing I see the SERVICE,
>> TYPENAME, BBOX, etc. Also there is no data download.
>> Best regards,
>> Arthur
>>> Your GML looks okay to me. You don't have any attributes (next to the
>>> geometry), but that should be no problem.
>>> Can you see the request go off with Firebug at all when adding the
>>> vector
>>> layer to your map? Are you using a proxy in between or is the traffic
>>> local?
>>> Best regards,
>>> Bart
