[OpenLayers-Users] zoom to different WMS layers
Paul Curran paulcurran9 at googlemail.com
Mon Aug 24 09:48:06 EDT 2009
I wish to have a map of the UK with different layers being displayed
depending on how close I am zoomed into the map.
Currently I can view a map of the UK which displays fine via OpenLayers.
However I can only view the first layer of my map (  a 1:50000 scaled image
of the UK). I wish to zoom in to the next layer of the UK (a 1:250 000
scaled image of the UK)
Is this possible with Openlayers?
Any help greatly appreciated
My code is below
Cheers
<script type="text/javascript">
      var zoom = 10;
      var bounds = new OpenLayers.Bounds(0, 0, 660046, 1229782);
      var map, layer;
      function init(){
          map = new OpenLayers.Map('map', { maxExtent: bounds,
maxResolution: 156543, units: 'meters',
          projection: "EPSG:4326", numZoomlevels: 10 });
      map.addControl(new OpenLayers.Control.PanZoomBar());
      map.addControl(new OpenLayers.Control.OverviewMap());
      map.addControl(new OpenLayers.Control.MousePosition());
      layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
      "http://127.0.0.1/cgi-bin/mapserv.exe?", { layers: 'uk', map:
'/ms4w/apps/openlayers-2.5/data/uk2.map' },
      { gutter: 15 });
      map.addLayer(layer);
      map.zoomToExtent(bounds);
      map.setCenter(bounds);
    </script>
MAP
    NAME UK1
            PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    SIZE 1600 1200
    IMAGECOLOR  153 204 255
    IMAGETYPE JPEG
    SHAPEPATH "http://localhost/openlayers/data/"
    #QGIS
    #EXTENT  -837824 -111116 1677552 1232884
    #Port Talbot
    #EXTENT 272000 187000 278000 193000
    #UK
    EXTENT  0 0 660046 1229782
    UNITS METERS
            WEB
              TEMPLATE "http://localhost/openlayers/examples/uktest.html"
              LOG "\ms4w\tmp\ms_tmp\log.txt"
      IMAGEPATH "\ms4w\tmp\ms_tmp\"
      IMAGEURL "/ms_tmp/"
      METADATA
                        'wms_title' "map"
        'wms_onlineresource'  "http://127.0.0.1./cgi-bin/mapserv?map=uk2.map
      END
            END
  LAYER
               NAME "UK"
               METADATA
                 'wms_title' "wms_demo"
               END
               STATUS DEFAULT
               TYPE raster
               TILEINDEX "map"
               TILEITEM "Location"
               PROJECTION
                        'proj=longlat'
                        'ellps=WGS84'
                        'datum=WGS84'
                        'no_defs'
               END
               CLASS
                 STYLE
                  COLOR 0 0 0
                 END
                 LABEL
                  COLOR 0 0 0
                  SIZE SMALL
                 END
               END
  END
  LAYER
               NAME "250"
               METADATA
               END
               STATUS DEFAULT
               TYPE raster
               TILEINDEX "250K"
               TILEITEM "Location"
               PROJECTION
                        'proj=longlat'
                        'ellps=WGS84'
                        'datum=WGS84'
                        'no_defs'
               END
               CLASS
                 STYLE
                  COLOR 0 0 0
                 END
                 LABEL
                  COLOR 0 0 0
                  SIZE SMALL
                 END
               END
  END
END
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090824/19f020d9/attachment.html
