[OpenLayers-Users] How to make a drag and drop for markers?
Jimmy Aumard jimmy.aumard at gmail.com
Mon Aug 24 11:21:55 EDT 2009
Thanks it's perfect for my application!!!
I just have to develop that :s
I have one question : It's possible to put an offset to the external
graphic? Because images of markers (marker.png) are centered on the center
of the image's marker and not on the bottom of the image's marker
I'm not sure I'm clear but it's difficult to explain this in English for
my...  Sorry
Cheers
Jim
2009/8/24 Alexandre Dube <adube at mapgears.com>
> Jimmy Aumard wrote:
>> Hello, thanks for answers,
>> My problème is I use markers and I put/update attributes on each in my
>> database. I don't know how put or update attributes with vector layer (if
>> you have an example I take it :D).
> You need a server that supports transactions :
>  - GeoServer
>  - TinyOWS
>  see the example :
> http://openlayers.org/dev/examples/wfs-protocol-transactions.html
>  - FeatureServer (uses MapFish protocol)
>  see a demo : http://dev4.mapgears.com/bdga-fs/
>  The FS demo also shows a way to edit feature's attributes.
>  I use vector layer for polygon with DragFeature. I know this solution but
>> points representation is a point an I use icon, It's possible to put an icon
>> to a point with a vector layer?
> Yes.  Look at the following example and search the source for the
> externalGraphic property.
> http://openlayers.org/dev/examples/styles-unique.html
> Regards,
> Alexandre
>> Sorry for my english :s
>> Cheers
>> Jim
>> 2009/8/24 Eric Lemoine <eric.lemoine at camptocamp.com <mailto:
>> eric.lemoine at camptocamp.com>>
>>    On Friday, August 21, 2009, Alexandre Dube <adube at mapgears.com
>>    <mailto:adube at mapgears.com>> wrote:
>>    > Hi,
>>    >   One way to accomplish this is to use a Vector layer instead of a
>>    > Marker layer and use a ModifyFeature control do move your points
>>    > (markers) around.
>>    The DragFeature control may be of interest as well.
>>    Eric Lemoine
>>    Camptocamp France SAS
>>    Savoie Technolac, BP 352
>>    73377 Le Bourget du Lac, Cedex
>>    Tel : 00 33 4 79 44 44 96
>>    Mail : eric.lemoine at camptocamp.com
>>    <mailto:eric.lemoine at camptocamp.com>
>>    http://www.camptocamp.com
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090824/d5c117cc/attachment.html
