[OpenLayers-Users] rewrite 00-map-with-wms.html in GWT and org.gwtopenmaps.openlayers library
www.gwtorm.com jim.pxie at gmail.com
Tue Aug 25 12:24:20 EDT 2009
Anybody uses GWT and org.gwtopenmaps library for Google maps.
When I convert js version into GWT version, Google map just occurs in upper
left of map widget instead of whole part of map widget. After I resize web
browser and change zoom level, I can get the same look as original js
version.
Please help.
Jim
On Mon, Aug 24, 2009 at 10:45 AM, www.gwtorm.com <jim.pxie at gmail.com> wrote:
> I am trying to rewrite 00-map-with-wms.html that is listed in
> http://workshops.opengeo.org/postgis-spatialdbtips/map-with-wms.html in GWT
> and org.gwtopenmaps.openlayers library. The original html is attached as
> 00-map-with-wms.html and GWT Java code is attached as SpatialDbTips.java.
> I have some problem in GWT version:
> 1. I have to resize web browser first.
> 2. I have to change zoom level then.
> After I did the above two steps, GWT version works the same as original
> html version.
> Thanks,
> Jim
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090825/288fc81f/attachment.html
