[OpenLayers-Users] Error-when-using-XMLHTTPRequest
Juan Arévalo arevaco90 at yahoo.es
Tue Aug 25 15:16:02 EDT 2009
Hi!
The problem it seems to be solved now..we couldn´t find the patch file that
you mentioned in your post. Here is the link in case that someone need it:
http://openlayers.org/pipermail/dev/attachments/20090428/30b57201/attachment-0001.obj
Thanks for your help!!
Juan
Juan Arévalo wrote:
> Hi all!
> All my WFS-T examples were working perfectly till today! However I am now
> getting an error when I try to modify my features and I cannot figure out
> where the problem is coming from. Here is the error:
> Error: uncaught exception: [Exception... "Component returned failure code:
> 0xc1f30001 (NS_ERROR_NOT_INITIALIZED) [nsIXMLHttpRequest.send]"  nsresult:
> "0xc1f30001 (NS_ERROR_NOT_INITIALIZED)"  location: "JS frame ::
> http://127.0.0.1:8080/client/mfbase/openlayers/lib/OpenLayers/Request/XMLHttpRequest.js
> :: anonymous :: line 200"  data: no]
> I´ve read this post in the forum regarding this problem:
> http://n2.nabble.com/Error-when-using-XMLHTTPRequest-through-refreshing-a-wfs-layer-every-n-seconds-td2721982.html#a2740217
> But to me it is not clear what needs to be done in order to solve this
> issue!
> My application was nearly finished so any help will be much appreciated!
> Thank you!
> Juan Arévalo
View this message in context: http://n2.nabble.com/Error-when-using-XMLHTTPRequest-tp3506570p3512002.html
