[OpenLayers-Users] SelectFeature on click problem
Brad Spencer brad at cubewerx.com.au
Wed Aug 26 20:09:24 EDT 2009
List,
I have been struggling with a SelectFeature on a vector layer. I create the
layers quite OK but am having trouble getting my popup to work on a mouse
click on feature.
My code snippet..
// pointFeature is the array of sorted point objects to be added as vector
markers
                userMarkers.addFeatures(filteredPoints);
                map.addLayer(userMarkers);
//Create a select feature control and add it to the map.
                 selectControl = new
OpenLayers.Control.SelectFeature(userMarkers,
                                                //hover: true
                                                onSelect: onFeatureSelect
                                                ,onUnselect:
onFeatureUnselect
                map.addControl(selectControl);
                selectControl.activate();
When I run this code it will NOT trigger the onFeatureSelect function but if
I set hover: true it does launch the function.
Can anyone see a problem with this - I am using 2.8
Cheers, Brad
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090827/1c27f5cb/attachment.html
