[OpenLayers-Users] Cluster strategy not working
Jerome Freyre jerome.freyre at hispeed.ch
Fri Aug 28 06:55:09 EDT 2009
Hi Max,
Personnally, when I use Cluster Strategy, I create separatly the strategy
and the I activate it.
			var strat = new OpenLayers.Strategy.Cluster({distance:20});
			vectorLayer = new OpenLayers.Layer.Vector("Vektorlayer",{
			strategies: [
				strategy
			styleMap: vectorStyle2, maxResolution: 19});
			strat.activate();
Hope it will be usefull....
Sincerly,
Jérome
Max Stephan wrote:
> Hi everybody,
> I`m having problems getting the cluster strategy to work. It simply makes
> no difference in terms of appearance if I add it to the VectorLayer or
> not.
> This is my code for the layer:
> 			strategies: [
> The reason why I want to add it is that I have 480 Features alltogether on
> my map and even when zooming into some areas there are still around 150
> features left in the bbox causing InternetExplorer to slow down (don´t
> know if it´s the same case with Firefox, but I gotta use IE to use
> ADODB-Connection to an Access Database in the Intranet).
> Those features are created and added step by step with an addVector-method
> I have implemented that reads out the coordinates and attributes of the
> database for a single feature and then jumps to the next entry and repeats
> the procedure till all features have been added.
> greets and thx in advance
> Max Stephan
View this message in context: http://n2.nabble.com/Cluster-strategy-not-working-tp3533851p3533951.html
