[OpenLayers-Users] Save Vector drawings in PostGIS
Paul Spencer pagameba at gmail.com
Fri Aug 28 13:16:21 EDT 2009
Try using tinyows, it is a lightweight c-based cgi that implements WFS
with transaction support and is backed by a postgres/postgis
database.  The WFS protocol in OpenLayers seems to work perfectly with
it, use the Save strategy to ensure every edit gets saved to the db
and you can use mapserver to draw maps with features from the db.
Cheers
Paul
On 2009-08-28, at 11:49 AM, AlessioDL wrote:
> Hi,
> I'm looking for a strategy to use OL as an editor to populate a
> polygon
> postgis layer.
> I can't use WFS-T because I have to work with UMN-Mapserver that
> doesn't
> support this specification.
> What I would like to do is this:
> (1) use the drawing tools to create my vector features on the map
> (2) capture the WKT string for these drawings in a form field
> (3) send an insert query to postgis via PHP
> The (1) and (3) are ok for me, but I need some help with the (2).
> Can you give me some suggestions?
> Is my "strategy" correct in your opinion?
> TIA, alessio
> View this message in context: http://n2.nabble.com/Save-Vector-drawings-in-PostGIS-tp3535558p3535558.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
