[OpenLayers-Users] Is there a way to get the absolute bounding box of a feature in a layer?
Ivan Grcic igrcic at gmail.com
Wed Dec 2 22:44:51 EST 2009
var feature_bounds= layer.getFeatureById(feature_id).geometry.getBounds();
http://dev.openlayers.org/docs/files/OpenLayers/Geometry-js.html#OpenLayers.Geometry.getBounds
map.zoomToExtent(feature_bounds,true);
cheers
On Thu, Dec 3, 2009 at 12:36 AM, cgp <carina_palanca at forcorp.com> wrote:
> Please see image attached.  http://n2.nabble.com/file/n4103130/feature.png
> My goal is to zoom in to a feature when I click on a button.
> My code would be essentially like this (assuming all required declarations
> are made):
> $("#zoomToFeatureButton").click(function(){
>     var feature_id = $("#input_feat_id").val();
>     var bounds =  getFeatureBounds(feature_id );       //get bounds of
> feature
>     zoomToFeature(bounds );
>        function zoomToFeature(data) {
>                var bounds = data.split("^"); //bounds passed in
>                var min_x = bounds[0];
>                var min_y = bounds[1];
>                var max_x = bounds[2];
>                var max_y = bounds[3];
>                var feature_bounds = new OpenLayers.Bounds(min_x, min_y, max_x, max_y);
> My problem is within getFeatureBounds(feature_id ). I can't seem to find
> anything that would allow me to get the bounding box of a feature. If I can
> get the min x, min y, max x and max y of a feature, will that let me create
> a Bounds object and use that for zooming?
> Thanks.
> View this message in context: http://n2.nabble.com/Is-there-a-way-to-get-the-absolute-bounding-box-of-a-feature-in-a-layer-tp4103130p4103130.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
