[OpenLayers-Users] optimization 2: openlayers.js
Ivan Grcic igrcic at gmail.com
Fri Dec 4 12:42:51 EST 2009
Mira, talvez te ayuda, pa OL 2.8. Tiene ke modificarla un pokito y ya :) Suerte
On Fri, Dec 4, 2009 at 3:56 PM, Guillaume Sueur
<no-reply at neogeo-online.net> wrote:
> Hi Valeria,
> Lite is maybe too lite for your needs, depending on which
> controls/formats... you use in your client. You should try to define
> your own build.
> Regards,
> Guillaume
> Le vendredi 04 décembre 2009 à 11:47 -0300, Valeria Muñoz a écrit :
>> Hi Ivan
>> thanks, i did that(lite.cfg) , but when i change it (.js) returned me
>> errors . :(
>> RG
>> 2009/12/4 Ivan Grcic <igrcic at gmail.com>
>>         http://docs.openlayers.org/library/deploying.html
>>         http://trac.openlayers.org/wiki/Profiles
>>         http://geowebguru.com/articles/212-optimizing-openlayers
>>         And after you build your custom OL, you can make your server
>>         to gzip files
>>         http://httpd.apache.org/docs/2.0/mod/mod_deflate.html
>>         It should come to around 150 I think.
>>         cheers
>>         On Fri, Dec 4, 2009 at 3:24 PM, Valeria Muñoz
>>         <valemunoz at gmail.com> wrote:
>>         > I download openlayer in my server, i use openlayers.js(696
>>         kb) but is so
>>         > heavy for the aplication... can i compress the JS or exist
>>         some compress
>>         > version?
>>         > RG
>>         > _______________________________________________
>>         > Users mailing list
>>         > Users at openlayers.org
>>         > http://openlayers.org/mailman/listinfo/users
>>         Ivan Grcic
>> Users mailing list
> Users mailing list
Ivan Grcic
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091204/a2083d0c/custom.obj
