[OpenLayers-Users] Understanding events
Yves Moisan yves.moisan at boreal-is.com
Wed Dec 9 10:13:15 EST 2009
> Wrap your function in anonymous instead.
> layers[0].events.register("loadend", layers[0], function(evt){
>   //do what you have to do here...
>    selectFeature(layers[0],oFeatures[0].fid));
Well, the use case is a bit more complicated.  I calculate initial
bounds for a feature then select that feature.  Then if my feature array
has more than one element I iterate through it and then features don't
get selected :
if(oFeatures && oFeatures.length > 0)
     var bounds = oFeatures[0].geometry.getBounds();
	layers[0].events.register("loadend", layers[0], function(){
	selectFeature(layers[0],oFeatures[0].fid);        });
	for(var i = 1; i<oFeatures.length;++i)
                        bounds.extend(oFeatures[i].geometry.getBounds());
                           selectFeature(layers[0],oFeatures[i].fid);});
I guess the event is triggered only once so iterating makes no sense ?
I thought it was the case so I just called the function directly in the
for like
but that didn't work either probably because the code gets executed
before the loadend was fired.  Do I have to set up an explicit delay
here or somehow bubble the event ?
TIA,
Yves
