[OpenLayers-Users] How to access style properties of features?
Andreas Hocevar ahocevar at opengeo.org
Mon Dec 21 07:48:32 EST 2009
Peter.Sykora at ooe.gv.at wrote:
>> Try feature.style.graphicWidth instead of
>> feature.Vector.style.graphicWidth.
> I tried that, and several other things as well but I didn´t get any results so far.
> Just to be sure that the problem is not the code of the rest of my project I added the following line
> alert (features[0].style.graphicWidth);
> to the styleMap Example (http://www.openlayers.org/dev/examples/stylemap.html)
> Again, features[0].style is null.
Ok, I thought your features come e.g. from a Layer.KML, which sets a
style property on the feature. Where do your feature styles come from,
or what makes you think your features have a style property (because by
default they don't, unless you set it)? I think that you have a
graphicWidth attribute in your features, not a style. So you would use
feature.attributes.graphicWidth to access that.
> I just wonder why there is a "style" property in OpenLayers.Feature.Vector but not in OpenLayers.Feature
Because OpenLayers.Feature is for Markers layers, and Markers layers
don't have the concept of a style.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
