[OpenLayers-Users] How to access style properties of features?
Andreas Hocevar ahocevar at opengeo.org
Mon Dec 21 09:35:53 EST 2009
Peter.Sykora at ooe.gv.at wrote:
> I use a styleMap that contains a user style, so I thought that this style should be accessible.
Ah, I see. This is not the case. The styleMap does not write style
properties on the feature.
> The strange thing for me is that with my custom functions e.g.: getChartURL or getSizeH I am able to set and influence the styling prameters but afterwards I´m not able to access their values.
This is expected behavior.
> var template = {
> 	fillOpacity: "${getOpacity}",
> 	externalGraphic: "${getChartURL}",
> 	graphicWidth: "${getSizeW}",
> 	graphicHeight: "${getSizeH}",
> 	strokeWidth: 0,
> 	graphicXOffset: "${getXOffset}",
> 	graphicYOffset: "${getYOffset}"
> style = new OpenLayers.Style(template, {context: context});
> styleMap = new OpenLayers.StyleMap({'default': style, 'select': {fillOpacity: 0.7}});
> With this style template I define the functions that calculate the styling parameters. E.g. the getSizeH function looks something like this:
> getSizeH: function(feature) {
> 	setDefaultValues(feature);
> 	var Sum = getSum(feature);
> 	var size = calcSize(feature,Sum);
> 	// Size for pin icons
> 	if (Sum==1) {
> 		if (feature.attributes.hover==1) {size=48} else {size=32}
> 	return size;
> This function works fine and sets the graphicHeight to the needed value. Somehow internally in OpenLayers this information must be stored, otherwise the features couldn´t be drawn correctly, but how can I access this information? I thought this should be in my user style
This information is stored in the DOM of the renderer and not meant to
be accessed.
> Maybe my problem is that the features themselfs never get a style assigned in my code.
Exactly.
>  They seem to get their styling information from the layers styleMap. But again the information about each individual symbols size in the map must be stored somewhere, but where??
It is calculated from the styleMap when drawing the layer. You can
access these properties like this. Let's say "layer" is your layer, and
"feature" a feature you are interested in:
var symbolizer = layer.styleMap.createSymbolizer(feature,
feature.renderIntent);
Now if you want to know your graphicWidth, you can access
symbolizer.graphicWidth
Note that createSymbolizer also takes the current scale into account for
calculating the symbolizer. And don't expect this technique to help if
you have a graphicHeight and want to know the graphicWidth. Some
renderers do not need the other value, and some calculate it before
rendering the feature, based on the size of the externalGraphic image.
Does this help?
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
