[OpenLayers-Users] Problems embedding OpenLayers in a Blog
jamesmikedupont at googlemail.com jamesmikedupont at googlemail.com
Wed Dec 23 11:56:58 EST 2009
I am looking at this example,
http://trac.openlayers.org/browser/trunk/openlayers/examples/osm-layer.html
It is using GML instead of OSM, and it is also loading from the
openstreetmap.org domain.
How can this example work if you cannot load map data from another domain?
mike
On Wed, Dec 23, 2009 at 5:16 PM, jamesmikedupont at googlemail.com
<jamesmikedupont at googlemail.com> wrote:
> Yes exactly,
> but if I host the page on archive.org then I can access the data on
> the same domain.
> I had a misconception about this whole thing, obviously mashups are
> going to create a lot more server sided traffic.
> mike
> On Wed, Dec 23, 2009 at 4:29 PM, Marc Jansen <jansen at terrestris.de> wrote:
>> Hi Mike,
>> as for OpenLayers, it shouldn't be a problem to get it hosted nearly
>> everywhere since it is only JavaScript. Obviously you cannot use any
>> datasource, though. Maybe you can set up a proxy that handles the requests,
>> but I'd doubt that it is possible for your current *.blogspot.com-adress.
>> Regards,
>> Marc
>> jamesmikedupont at googlemail.com wrote:
>>> Thanks for your advice. That is interesting.
>>> I never did anything like this, and I feed pretty stupid right now!
>>> But it will be possible to host the webpages on archive.org as well
>>> and work without the blog itself. It just would be nice to separate
>>> the display and the data storage. That effectively reduces the usage
>>> of openlayers to people who have control of domains, right? It will
>>> not be possible to people to just create maps with any data they want
>>> without a server to proxy the data.
>>> Now, this example, it displays an openstreetmap map
>>> http://osmopenlayers.blogspot.com/2009/12/test-of-osm-server.html
>>> but the fetch to :
>>> http://www.openstreetmap.org/api/0.6/way/24315294/full
>>> that fails, or never returns.
>>> But the same one to use open layer to load the data from osm fails :
>>> http://osmopenlayers.blogspot.com/2009/12/get-osm-data-directly.html
>>> It calles get on this url
>>> in the request  XMLHttpRequest.js (line 200)
>>> the other thing is that I dont get any error message about security
>>> problems
>>> I found this document here:
>>> http://docs.openlayers.org/library/request.html
>>> So, realistically it is not possible to host open layers on a blog?
>>> mike
>>> On Wed, Dec 23, 2009 at 1:37 PM, Marc Jansen <jansen at terrestris.de> wrote:
>>>> Hi Mike,
>>>> I am pretty sure that you aren't allowed to acces datasources via
>>>> XHR/AJAX
>>>> from other servers than the one the original page is served from.
>>>> see: http://en.wikipedia.org/wiki/Same_origin_policy
>>>> Just a quick guess, though.
>>>> regards,
>>>> Marc
>>>>> Hi there,
>>>>> I have attempted to embed openlayers in a blog post,
>>>>> and am failing! Any help would be appreciated.
>>>>> using osm data hosted OSM data on archive.org
>>>>> http://osmopenlayers.blogspot.com/2009/12/test-embed.html
>>>>> here is get a octet bytestream because archive org does not say the
>>>>> right filetype.
>>>>> http://ia341335.us.archive.org/2/items/ZCTA_NJ/zip_07003.poly.osm this
>>>>> returns a 206 partial content and fails.
>>>>> in a pastebin file that is delivered as text:
>>>>> http://osmopenlayers.blogspot.com/2009/12/hosting-on-pastebin.html
>>>>> Date    Wed, 23 Dec 2009 10:15:43 GMT
>>>>> Server  Apache/1.3.33 (Debian GNU/Linux) mod_python/2.7.10 Python/2.3.4
>>>>> PHP/4.3.10-22 mod_perl/1.29
>>>>> X-Powered-By    PHP/4.3.10-22
>>>>> Content-Disposition     attachment; filename="f28514ba0.txt"
>>>>> Keep-Alive      timeout=15, max=100
>>>>> Connection      Keep-Alive
>>>>> Transfer-Encoding       chunked
>>>>> Content-Type    text/plain; charset=iso-8859-1
>>>>> So the problem might be the attachment...
>>>>> and that data from osm directly again on pastebin,
>>>>> http://osmopenlayers.blogspot.com/2009/12/osm-data-from-xml-output-on-pastebin.html
>>>>> data is here :http://pastebin.com/pastebin.php?dl=f290d5ea6 it returns a
>>>>> 200 ok.
>>>>> It returns an : text/plain; charset=iso-8859-1 but does not render.
>>>>> But there is still nothing there
>>>>> from osm directly
>>>>> firebug says :no element found
>>>>> And my last try was to put the code from osm on the page directly,
>>>>> also not rendering but the xml is loading.
>>>>> but nothing is working
>>>>> would appreciate any tips and help
>>>>> thanks
>>>>> mike
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
