[OpenLayers-Users] Distance errors on Google maps
Jennifer Strahan
jennifer at greeninfo.org
Sun Feb 1 15:47:22 EST 2009
Hi Peter,
Back in Oct/Now I wrote to Tim Schaub asking about measurements when
working with Spherical Mercator and he sent me a few responses that I'm
copying below for you.
Regards,
Jennifer
*First response:
*Regarding the measure control, this provides planar instead of geodesic
measures (as is true with ArcMap and other GIS software). So, when you
measure a length, you are getting the straight-line distance between
points on a projected plane instead of the shortest distance between
points on a spheroid. Same goes for area - planar area instead of
surface area of a spheroid.
So, yeah, your spatial reference system is important. And spherical
mercator will be worse the farther you are from the equator. So, for a
couple points around San Francisco:
point 1: -13625500, 4551200
point 2: -13625250, 4551200
planar distance: 250 m
geodesic distance: 198 m
That is pretty bad.
The solution with lines is to use a geodesic calculation (which we
provide with OpenLayers.Util.distVincenty). For areas, this is more
complicated - as it involves dividing an arbitrary polygon into
triangles and running spheroid areas on those (which we don't have a
function for in the library).
One solution would be to transform the polygon to a more appropriate
projection before calculating the area. I can't get in to more detail
on this now, but if you haven't found another solution, we can talk more
about this.
Tim
*A few weeks later he sent this:*
Hey-
In case you don't see it on the OL dev list, I've put up a patch to do
geodesic measures with the measure control.
This assumes that you have provided the proj4js definitions for your map
projection.
http://trac.openlayers.org/ticket/1819
Let me know if it works for you.
Tim
Peter Robins wrote:
> I have a program that displays kml linestrings on either topo maps or google.
> I'm using getLength() to display the length of the segments, and noticed
> significant errors on the google display, in some cases 60% or more. I'm
> also using the scaleline, which is also wrong on Google.
> Thinking this was probably some error in my logic, I tried some simple tests.
> The topo maps conveniently include a 1km grid, so I drew some 1km lines on
> the grid (as close as I could make it) and saved them to kml. This gave me
> coordinates that I knew were 1km apart (on the topomap projection). I then
> used the Google api:
> var p1 = new GLatLng(42.87420777239693,-8.547039046722437);
> var p2 = new GLatLng(42.87483907990915,-8.534868375601192);
> alert(p1.distanceFrom(p2));
> This gave me 0.995km, so Google agrees that these 2 points are 1km apart.
> (Google's docs say their calculations may be up to 0.3% out because of the
> spherical assumption they use; this is no problem at the scales I'm using.)
> I then took OL's spherical mercator example page, and added my kml file. The
> scale line incorrectly showed the 1km line as well over 1km long. I then did:
> var p1 = new OpenLayers.Geometry.Point(-8.534868375601192,42.87483907990915);
> p1.transform(map.displayProjection, map.projection);
> var p2 = new OpenLayers.Geometry.Point(-8.547039046722437,42.87420777239693);
> p2.transform(map.displayProjection, map.projection);
> alert(p1.distanceTo(p2));
> This gave me 1.358km.
> Thinking there might be some problem with the spherical mercator calculations,
> I tried removing 'sphericalMercator: true' and using proj with different
> projection objects. I found several defs on spatialreference.org,
> and used SR-ORG:6 and SR-ORG:6627; I also used the new EPSG:3785. These defs
> are all very similar, so I was not surprised to get the same error: 1358m.
> Those 2 points are in Spain, EPSG:23030, but I also tried other places. One
> 5.2km line in GB, as measured on OS maps, EPSG:27700, was 8.4km according to
> OL Google getLength().
> I would expect discrepancies when dealing with different projections. I would
> expect rounding errors when transforming lots of points on a linestring. But
> these errors are so large the figures are effectively useless.
> Am I doing something wrong, or missing some vital step somewhere? Is it an
> error in OL's calculations? Or is it one of those complicated projection
> issues, where it would be simpler to use Google's api not OL if I want
> linestring lengths?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Jennifer Strahan, GIS Specialist
GreenInfo Network - www.greeninfo.org -
Information and Mapping in the Public Interest
**As of Oct. 13, 2008 we have a new address**
564 Market Street, Suite 510
San Francisco CA 94104
Phone: 651-917-0191
Fax: 415-979-0371
Email: jennifer at greeninfo.org
