[OpenLayers-Users] How can I show a picture a popup (URL for the pic should be read automatically from the attributes)
Ivan Grcic igrcic at gmail.com
Wed Feb 4 03:18:41 EST 2009
Hi, did you check out http://openlayers.org/dev/examples/GMLParser.html
Function load takes ur xml data (which can be getFeatureInfo), and
gives it to parseData function, which parses all the features and
their attributes...its all you need ;)
And i suggest to make it in JSON format, its much lighter
        function load() {
            OpenLayers.loadURL("gml/owls.xml", "", null, parseData);
        function parseData(req) {
          g =  new OpenLayers.Format.GML();
          html = ""
          features = g.read(req.responseText);
          for(var feat in features) {
            html += "Feature: Geometry: "+ features[feat].geometry+",";
                html += "<ul>";
            for (var j in features[feat].attributes) {
                html += "<li>"+j+":"+features[feat].attributes[j]+"</li>";
                html += "</ul>"
          document.getElementById('output').innerHTML = html;
Cheers
On Tue, Feb 3, 2009 at 9:09 PM, Max Stephan <x.zam at gmx.net> wrote:
> Ok, that sounds like an idea.
> I´ve been reading a bit more about JavaScript-development in general. So I
> developed the following change in the setHTML-function that allows me to
> show a picture when the function is executed.
> function setHTML(response){
> var img = document.createElement("img");
> img.setAttribute("src", "qu18_2.jpg");
> document.getElementById('nodelist').innerHTML=response.responseText;
> document.getElementById('pic-container').replaceChild(img,document.getElementById('pic-container').lastChild);}
> This works fine for a predefined pic. But how can I get the specific
> attribute that contains the URL out of the getFeatureRequest-response. So
> what I´m searching for is something like "response.getContent[5]" (fictional
> code ;-)).
> So, as you see, by now it´s a bit abstract to me what I exactly get back
> from this getFeatureRequest and how I can get further informations out of
> it...
> Thank you for your help Ivan and Till and thanks to everyone else in advance
> Max Stephan
> Till Adams wrote:
>> Max,
>> in general you need to define your output format which comes back from
>> Geoserver as text or Xml or whatever - then you may parse the backcoming
>> stuff and put the URL in an html image tag - basically you can see what to
>> do regarding the OL featureinfo example::
>> you must do alter it at the place when you receive the result from your
>> WMS
>> back and before you put it this in the result-div in your client - you'll
>> have to parse it and rewrite it to html, alternatively you may define a
>> template for your WMS which gives the results back in Html, so you can do
>> sth like:
>> <html>
>>  [URL]
>> Where [URL] will be filled by your WMS server - this is mainly the
>> proceeding I know from UMN mapserver.
>> Just some ideas - regards, Till
>> "Max Stephan" <x.zam at gmx.net> schrieb:
>>> Hey everybody!
>>> I got a shapefile here which I added to my geoserver. I have integrated
>>> it
>>> as a layer in an openlayers map container. In the attributes of the
>>> layer/shapefile is a field which contains an URL to a pic of each feature
>>> (in this case the features are points). Now I want this picture to be
>>> displayed in a popup (like it can be done in a marker layer). But I want
>> to
>>> have the URL automatically read from the attributes of the feature I´m
>>> clicking on. It would be great to see some of the other attributes read
>> from
>>> the feature as well. The problem is I don´t know that much about the
>>> OpenLayers-API. I only know how to write a GetFeatureRequest but this
>> would
>>> show me only the attribute table. If it´s too difficult to show a picture
>>> which´s URL is in the attributes it would be even enough if the URL in
>>> the
>>> attribute table (the one I get from the GetFeatureRequest) would be
>>> clickable.
>>> Greets and thanks for your help in advance Max Stephan
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> View this message in context: http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2265382.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Ivan Grcic
