[OpenLayers-Users] Google basemap with overlay layer
Marcello Brunaldi
marcello.brunaldi at student.unife.it
Mon Feb 9 11:08:00 EST 2009
I changed my code in this way
Now I will display the marker at the right distance but the coordinates do
not correspond to reality but the wms layer unesco not be seen.
I need to change the encoding in Geoserver EPSG from 4326 to 900,913 for the
wms layer unesco?
function init()
options={
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
numZoomLevels:18,
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508.34,
-20037508.34,20037508.34, 20037508.34)
//creo la mappa di base con i parametri
map = new OpenLayers.Map('map', options);
var myBaseLayer = new OpenLayers.Layer.Google("Google",
{'sphericalMercator': true,
'maxExtent': new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)
//creo i livelli con la zona unesco
unesco = new OpenLayers.Layer.WMS(
"TOPP unesco",
"http://localhost:8080/geoserver/wms?",
layers: 'topp:unesco',
styles: '',
srs: 'EPSG:900913',
format: 'image/png',
tiled: 'true',
tilesOrigin : "0,0",
transparent: true
'opacity': 0.5, 'isBaseLayer': false, 'wrapDateLine':
true
file[0] = "georss/blu.xml";
file[1] = "georss/rosso.xml";
file[2] = "georss/verde.xml";
file[3] = "georss/giallo.xml";
file[4] = "georss/marrone.xml";
file[5] = "georss/arancio.xml";
file[6] = "georss/celeste.xml";
file[7] = "georss/viola.xml";
file[8] = "georss/bianco.xml";
file[9] = "georss/nero.xml";
new1= [];
new1[0] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/blu.xml',
{'icon':color[0]} );
new1[1] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/rosso.xml',
{'icon':color[1]} );
new1[2] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/verde.xml',
{'icon':color[2]} );
new1[3] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/giallo.xml',
{'icon':color[3]} );
new1[4] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/marrone.xml',
{'icon':color[4]} );
new1[5] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/arancio.xml',
{'icon':color[5]} );
new1[6] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/celeste.xml',
{'icon':color[6]} );
new1[7] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/viola.xml',
{'icon':color[7]} );
map.addLayers([myBaseLayer,unesco]);
//map.addLayers([unesco,aste]);
//map.addLayers([unesco,aste,siepi,attrezzature,aree,alberi,edifici]);
for (n=0; n < 8; n++)
map.addLayer(new1[n]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
loadsetmap();
map.addControl(new OpenLayers.Control.Permalink());
map.addControl(new OpenLayers.Control.MousePosition());
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090209/6a4d9c08/attachment.html
