[OpenLayers-Users] setCenter zooming problem.
Christoph Boehme christoph at b3e.net
Wed Feb 11 11:03:35 EST 2009
I had the same problem when I loaded the location and zoom level from a
cookie. It turned out that the problem was caused by the cookie
(obviously) returning string values. The zoom-in code in OL contains a
line which computes zoomLevel+1 which works fine for numbers but results
in concatenation if zoomLevel is a string. After making sure that
setCenter receives the zoom as a number (with Number(zoom)) it was
working fine.
Christoph
bzrudi wrote:
> Hi all!
> I have a strange problem and one may know a simple solution. I use
> setCenter() to center and zoom the map to a given location.
> This works as expected without any problem. The problem is I can't zoom
> in before zooming out one level first.
> So in detail, open the map:
> - use doubleclick, mousewheel or use zoompanel to zoom in -> nothing
> - use doubleclick, mousewheel or use zoompanel to zoom out -> works!
> now you can zoom in without any problem.
> I don't have the problem when not using setCenter(). E.g. zooming in
> from max entent works.
> Any idea?
> Thanks in advance!
> cheers bzrudi
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
