[OpenLayers-Users] Revised: C# Proxy for OpenLayers
carls carlshe at 163.com
Wed Feb 11 12:08:55 EST 2009
<%@ WebHandler Language="C#" Class="Proxy" %>
using System;
using System.Web;
using System.Net;
using System.IO;
using System.Text;
using System.Configuration;
public class Proxy : IHttpHandler {
    public void ProcessRequest (HttpContext context) {
        HttpWebRequest request =
(HttpWebRequest)WebRequest.Create(context.Request["url"]);
        request.UserAgent = context.Request.UserAgent;
        request.ContentType = context.Request.ContentType;
        request.Method = context.Request.HttpMethod;
        byte[] trans = new byte[1024];
        int offset = 0;
        int offcnt = 0;
        if (request.Method.ToUpper() == "POST")
            Stream nstream = request.GetRequestStream();
            while (offset < context.Request.ContentLength)
                offcnt = context.Request.InputStream.Read(trans, offset,
1024);
                if (offcnt > 0)
                    nstream.Write(trans, 0, offcnt);
                    offset += offcnt;
            nstream.Close();
        using (HttpWebResponse response =
(HttpWebResponse)request.GetResponse())
            context.Response.ContentType = response.ContentType;
            using (Stream receiveStream = response.GetResponseStream())
                offset = 0;
                offcnt = receiveStream.Read(trans, offset, 1024);
                while (offcnt>0)
                    context.Response.OutputStream.Write(trans, 0, offcnt);
                    offset += offcnt;
                    if (offcnt >= 0)
                        try
1024);
                        catch (Exception)
                            break;
                    else
                        break;
            context.Response.OutputStream.Close();
            context.Response.Flush();
            response.Close();
    public bool IsReusable {
        get {
            return false;
Regards, Carl SHE
View this message in context: http://n2.nabble.com/upload-C--version-of-Proxy-for-OpenLayers%3A-Proxy.ashx-url%3D-tp2307110p2309924.html
