[OpenLayers-Users] Zoom works partialy
Christopher Schmidt crschmidt at metacarta.com
Wed Feb 11 14:43:56 EST 2009
On Wed, Feb 11, 2009 at 08:16:39PM +0100, Detlef Reichl wrote:
> Hi,
> i have a strange problem. I have a map, which uses two OpenStreetMap
> layers and a Marker layer on top.
> With an old version of my code - only simple functions, no OO patterns -
> zooming worked like expected. After a redesign to encapsulate it all in
> objects, the zoom function behaves very strange.
> After I load the map zooming with the scroll wheel, double clicking on
> the map and clicking on the "+" of the PanZoomBar doesn't work (also the
> registered event handlers are not called), clicking in the PanZoomBar or
> on the "-" of it change the zoom level like expected. After the first
> zoom, the scroll wheel and the "+" of the PanZoomBar also work. Panning
> the map with the mouse works all time and registered event handlers are
> also called.
You must be very new to the list, since the previous email to yours,
sent just 4 hours ago, was the exact same problem.
http://openlayers.org/pipermail/users/2009-February/010353.html
> I've tested it with 2.7 and trunk.
> The code, that creates the map object is in
> http://bitbucket.org/sttmjoc0/osm-pforzheim-unstable/src/tip/slippy-map/js/ow-slippy-map.js
> Any ideas?
> Cheers, detlef
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
