[OpenLayers-Users] Min Zoom Level
Warren Vick
wvick at europa-tech.com
Thu Feb 12 08:46:16 EST 2009
Ah, I see.
So, the final part of my question is... what are the scale values for
the standard zoom levels in OL? Is it the same as
Min/MaxScaleDenominator when rendering TMS tiles?
Regards,
Warren
-----Original Message-----
From: Matthias Woltering [mailto:woltering at gmail.com]
Sent: 12 February 2009 13:29
To: Warren Vick
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Min Zoom Level
Hi Warren,
if you add the PanZoomBar
map.addControl(new OpenLayers.Control.PanZoomBar());
you will have as much zoomlevels as you have defined in the
scales-section. In the previous example there will be 7 zoom-levels.
Regards,
Matthias
Warren Vick schrieb:
> Hi Matthias,
> Thanks for the prompt feedback. How would changing the scale of each
> zoom level limit the number of levels available to the user? In my
case,
> I have 11 zoom levels but want to start at level 6. So, my zoom
control
> would only represents the levels between 6 and 11.
> Regards,
> Warren
> Sent: 12 February 2009 13:00
> To: Warren Vick
> Hi Warren,
> you can set set the scales manually like this:
> var options = {
> maxExtent: new OpenLayers.Bounds(1430000,4400000,1760000,4660000)
> ,maxResolution: "auto"
> ,scales: [1000000,500000,250000,100000,50000,25000,10000]
> ,units: 'm'
> ,projection: 'EPSG:31466'
> ,controls: []
> //,zoom: 1
> //,numZoomLevels: 8
> map = new OpenLayers.Map('map', options);
> If you don't want to set scales use numZoomLevels.
> Regards,
> Matthias
>> How can I set a minimum zoom level for a map? Focussing on a single
>> country, I know how to limit the extent but can't figure out how to
> stop
>> someone zooming out and seeing TMS tiles that have not been rendered.
>> Regards,
>> Warren
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
