[OpenLayers-Users] Query to ArcIMS layer is not available?
carls carlshe at 163.com
Sat Feb 14 08:48:12 EST 2009
The problem is resolved.
I found that the 'id' of a layer is not same as its 'name'. While using
ArcIMS to create a map, only name of every layer is displayed. I just
mistook the 'name' of layer for its 'id'.
The 'id' of each layer can be gotten by opening the map configuration file
'*.axl' with NotePad.
carls wrote:
> I tried the ArcIMS layer and ArcXML provided by Ticket#213 sucessfully.
> But when I setQuery to a layer, it seems no effect to the result.
> the code is listed below.
> <html xmlns="http://www.w3.org/1999/xhtml">   <head>
>     <title>Local ArcIMS Example</title>
>     <link rel="stylesheet" href="./OpenLayers/theme/default/style.css"
> type="text/css" />
>     <link rel="stylesheet" href="style.css" type="text/css" />
>     <script src="OpenLayers/lib/OpenLayers.js"></script>
>     <!--<script src="OpenLayers/lib/Proj4js/proj4js.js"></script> -->
>     <script type="text/javascript">
>         var lon = (-122.496415 - 122.384637) / 2;
>         var lat = (37.728692 + 37.794956) / 2;
>         var zoom = 10;
>         var map, layer;
>         function init(){
>             //OpenLayers.ProxyHost = "proxy.ashx?url=";  //only necessary
> for cross-domain access
>              map = new OpenLayers.Map( 'map' );
>              var options = {
>                                serviceName: "SF",
>                                async: true,
>                                displayOutsideMaxExtent: true,
>                                layers: [
> true,
>                                                      query: { where: '1>2'
>             layer = new OpenLayers.Layer.ArcIMS( "local Map",
>  "http://localhost:8080/servlet/com.esri.esrimap.Esrimap", options);
>             map.addLayer(layer);
>             map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>     </script>
>   </head>
>   <body onload="init()">
>     <h1 id="title">ArcIMS Example</h1>
>     <div id="tags">
>     </div>
>     <p id="shortdesc">
>         Shows the basic use of openlayers using an ArcIMS layer
>     </p>
>     <div id="map" class="smallmap"></div>
>     <div id="docs">
>         This is an example of how to add an ArcIMS layer to the OpenLayers
> window.
>     </div>
>   </body>
> </html>
> Could somebody help me?
> Thanks very much.
Regards, Carl SHE
View this message in context: http://n2.nabble.com/setQuery-to-ArcIMS-layer-is-not-available--tp2325774p2326265.html
