[OpenLayers-Users] Dragging vectors
Brad Spencer brad at cubewerx.com.au
Sun Feb 15 19:19:11 EST 2009
Thanks Ivan that did the trick. I must have been blind to miss that:).
Anyway, I have another issue. These vector circles are of different sizes
and I am wanting to use hover as the popup trigger. However, the smaller
symbols that fall inside the larger ones [at smaller scales] are not
accessible to the mouseover - only the larger vector's popup is visible.
I thought I could control this by setting a graphicZIndex on the default
symbolizer such that the smaller ones were 'higher' in the zIndex stack than
the larger ones and moving over a small one (even if inside the larger one)
would trigger its popup.
But its not doing what I thought it should. Can someone please scan over
this example for me to advise how to do this.
http://demos.numaps.com.au/dragVectors.html
Cheers, Brad
-----Original Message-----
Sent: Sunday, February 15, 2009 10:17 PM
To: Brad Spencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] Dragging vectors
Hi ,
try:
control.activate();
Cheers
On Sun, Feb 15, 2009 at 8:41 AM, Brad Spencer <brad at cubewerx.com.au> wrote:
> Hi List,
> I have moved away from Markers in order to take advantage of the better
> support for vectors, specifically dragging of.
> I have looked at the various examples etc and have made my own test
> application that is doing what I want with the exception of dragging.
> This example will generate 5 vector points with different sizes of symbol
> radius based on a variable when creating it. I also create different
> behavior when hovering over the symbol such as changing its colour and
> generating a popup with additional data included.
> However, it will not allow me to drag the vector feature to a new
location.
> Can anyone show me where I am going wrong or if indeed this can be done at
> all.
> Cheers,
> Brad Spencer
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
